Thread: 90 DA Teggy Project- Wire tucked, setup for Brake tuck, lots of parts
    WeRd!
    Default 90 DA Teggy Project- Wire tucked, setup for Brake tuck, lots of parts
    so, i have decided to go a different direction and build something different. i sold my b-swap out of the car a few weeks ago and picked up a K and intended to put it in the DA, but ive decided to go with a different platform.
    its a 1990 Integra GS. has power windows, sunroof, all the options but leather.
    THE GOOD:
    Headlight harness has been tucked
    Wire harness tucked inside the cabin
    Has a mint dash and seats, although the seats are mis-matched, one from a 90-91 one from a 92-93
    Dash switch panel has been shaved, filled, and painted and cleared
    RARE USDM GSR INSTRUMENT CLUSTER
    Brake booster has been refinished and painted satin black
    All dents, dings, pings, everything bodywise has been pulled and fixed
    2 sets of taillights, 1 set of 90-91 non-amber, one set of 92-93 amber that have been tinted
    1.5" inch extended top hats for oem or aftermarket struts
    MOROSO Battery terminals mounted inside the engine bay behind the passenger headlight for tucked battery
    minty headlights and fogs
    92-93 front bumper
    all sound deadening has been removed and dash has been gutted for the brake tuck and wire tuck, although, it could all be put back in and the prop valve just relocated. i was just gonna go without it since i wasnt gonna run a/c or heat
    Door windows work flawlessly and seal up great, which is a common problem area on DA's
    ENTIRE ENGINE BAY HAS BEEN SANDED PREPPED AND PAINTED DUPONT HOT HUES PURPLE ALL THE WAY OUT TO THE RADIATOR SUPPORT
    The inside of the cowl has been sealed as well, which is another problem area on DA's and it has been refinished and satin blacked as well
    The rear engine crossmember has been repainted satin black and the front crossmember has been covered in DEI heat-barrier
    THE BAD:
    needs to be finish sanded for primer
    hood had not been worked yet and is still shiny, but it only has a couple dings in it and it wont take much to get it going again
    few nicks in the engine bay where the motor was reinstalled
    no shift linkage
    sunroof has a crack, but doesnt leak and works flawlessly
    windshield has a crack in the lower driver corner, but isnt really noticeable
    no engine harness
    carpet was destroyed so its gone
    car is disassembled, but i have all parts to put it back together, all moldings, trim, etc. i have thought long and hard about this and it kills me with all the hard work i have put into this car, but its just not what i really want to build and i dont want to keep building on a car that i prob wont keep anyway. so my loss is your gain.
    *************PRICE DROP!!!*****************
    $400 for everything listed
    NO REASONABLE OFFER WILL BE REFUSED
    BEFORE BODY WORK
    WIRE TUCK AND BRAKE TUCK
    AS OF RIGHT NOW
    Rome, GA
    Glws, bump for looking.
    Columbus, OH
    geez u guys and the time spent on a car...
    pretty though
    CHASE ->>>
    WHAT MATTERS
    Sep 2008
    Does it have a title? What rims come with it? Interior?
    Watagatapitusberry ThE_EnD's Avatar
    Snellvegas
    wow, sad to see it for sale, but hopefully someone will pick her up and finish what you started. GLWS, you deffinatly but alot of time and money into this car.
    Sep 2008
    Quote Originally Posted by ThE_EnD View Post
    If it has a title, I'll be VERY interested. I miss my DA.
    Southside Ridin HATCH
    Man i am kicking myself in the ass rite now!
    400 for this shell that is allready Done up, READY for a motor.. well and some paint but yea
    Damn good deal if you ask me!!
    ^if it also has a title
