Thread: crankshaft?
    georgia
    Default crankshaft?
    ok i finally got a good core and tore it down for my rod and piston up grade.the guy i go it from said it was rebuilt new bearings and rings,and by the looks of it thats true.
    my question is do i need to get the crank turned to use better bearings?? or can i just swap them with the stock replacements that were in there? the crank looks to be perfect with no scoring ir discolored spots and the bearings were fresh.
    i want to be sure cause i have heard of people re using stock cranks with stock spec bearings and they work perfectly for a long time. is this true?
    yes i am....
    if the crank as been stored in the block tq down. i wouldnt worry about anything other than scars on the journals but if everything is good there. u might just want to have it polished and sized for bearing just to be sure oem is what u need. then call it day.
    georgia
    yeah its been on the block right now its standing on end in the corner until i decide what im gonna do. ive got bearing numbers from the old ones i could cross refrence those right??
    yes i am....
    don't turn it, honda cranks are only flash hardened, turn the crank and you take the hardness away. Then your crankshafts life is much shorter and you will probably spin a rod bearing much sooner also. That is unless you spend several hundred dollars to get the crank re-hardened.
    My line of work
    www.internationaljets.com
    EF'N dirtragz's Avatar
    Jul 2009
    the ham
    ^ what he said
    88 crx hf lsvtec 153hp 117tq mainstream
    You always lose money chasin' hoes, but you never lose hoes chasin' money.
    Quote Originally Posted by Civichatch91 View Post
    I will never cheap out again...I should have known better
    GWINNETT IS GREAT!
    yo you tryna build a non vtec d ?
    georgia
    yes sir,no vtec for me
    never been a fan of vtec and i would also like to add i feel the same way about the jdm trend lololol
    yes i am....
