Thread: H22 with B-series trans aka H2B adapter plate EG CRX EJ
    SickSwapp-eR spooled's Avatar
    ATL baby
    Default H22 with B-series trans aka H2B adapter plate EG CRX EJ
    I have the adapter plate and flywheel spacer. I used the same setup to mount an F22 to a B-series transmission. The adapter and spacer can be used for either a H22 or F22 engine. I have one custom made for my setup and one other IA member. I have 2 extras I made for anyone interested.
    Interested buyers if you have any questions please PM me.
    You can also text me at 404-438-8839
    $200 obo
    Details:
    High tensile strength steel construction
    3/8" Thick
    Includes hardware to mount the plate to the engine
    Thanks.
    Sick Swapp-eR
    ........... PrOjEk_EJ's Avatar
    H2b ftw gl
    Marietta, GA
    interesting, didn't know it was possible. good stuff, glws
    Certified Gearhead draggbody's Avatar
    Jul 2009
    columbus, ga
    what axles do you use for this??
    b series
    somewhere, GA
    good deal right here!
    '82 TE72 SR5 Sport Coupe
    3tc
    ATL baby
    Quote Originally Posted by draggbody View Post
    You use b-series axles and 98+ prelude halfshaft. Some minor machining of the block required just like the other h2b kits to properply clear the driver side axle.
    Sick Swapp-eR
    Where did you find the M12x1.25x35 bolts????!!!!!????? Im still having trouble finding some for mine. I have all the other stuff needed to make a full kit if you need anything. I still dont understand why you used steel though....heaveeeyyy
    ATL baby
    Quote Originally Posted by Jenson View Post
    If you need help with your kit PM ME PLEASE!!! After this post if you want to discuss my design I may consider it but in a PM format ONLY!!! With the laser I use, steel is much easier for me to machine to keep my costs low. If you use the correct grade/thickness of aluminum to make an aluminum adapter then your adapter would weigh about 1-2 lbs less than the steel adapters I make. This was not enough of a weight reduction for me to justify the huge additional cost.
    Thanks.
    Sick Swapp-eR
    Ahhh, laser...gotcha. I just need help finding these dang bolts! Im not knockin your stuff, just was curious is all. Away to the pm's and another bump for you.
    KindaInformedNoob! Joppa_Smoot's Avatar
    Augusta Ga
    im kinda lost, it'll only work on eg and ef's? cause i have an ek and wanna go h2b...lmk fam
    ATL baby
    Quote Originally Posted by Joppa_Smoot View Post
    It will fit into an ek. It will fit in any chassis you can do a gsr swap. The ef chassis will need modification to the transmission mount up point and the crx needs modification to the drv side frame to fit.
    Sick Swapp-eR
