Thread: firing order
    Default firing order
    what's the firing order for a 1995 integra LS. the spark plug wire to the dizzy. also, the head got oil in there? like the spark plug wire and spark plug is all wet. does it cause the car not to start? can the gasket for the valve cover be ripped?
    PURP-a-trader PURP's Avatar
    omg.... Google it...
    results will show very quickly
    Southside
    Quote Originally Posted by EJ1soSlo View Post
    1-3-4-2
    homo
    Southside
    Quote Originally Posted by GOT_PURP View Post
    homo
    lol I was gonna send that in a rep to you, but couldn't spread my yummy goodness
    bwhahahahahahahahaha
    if the valve cover is torn, can the motor still crank. like there's a lot of oil in my head causing my spark plug wires and plugs to be wet.
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    dude the plugs are prob covered in oil 2 replace them then try
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    If the gasket around your spark plug hole is torn it will allow oil to get on top of your spark plug and that can cause firing issues.
    For the firing order: if you are standing on the passenger side looking at the distributor, bottom left is 1, top left is 3, top right is 4, bottom right is 2. The spark plug closest to the timing belt is #1 and 4 is closest to the distributor.
    thanks for all the people that helped. i think i got a bad dizzy causing my car not to start. reps for all that helped. instead of google.
    gwinnett
    i didnt get repped ??
    haha srry man. i gotta spread some more love first before i can repp you agian.
    Quote Originally Posted by ls-r teg View Post
    im down right fierce hadouken's Avatar
    its ok ill give you some love =]
