Results 1 to 22 of 22
Thread: e30 springs?
    WillAgreeForReps!!
    The Town of Lula
    Default e30 springs?
    just picked up an e30 with some cut springs. looking to go to some aftermarket lowering springs. most lower the car about and inch and a half. i came across these:
    http://www.andysautosport.com/bmw/19...s00166293.html
    they spec it lowers it 2.4 inches. anybody have any input on these?
    any better options? i'd like as much drop as possible w/o it ridin like garbage. thanks!!
    Never used them, mine came with cut too I am about to get H&R race springs.
    I'll sell you my cuts for $20, perfect stance, no weird riding, not bumpy,and slammed! lol
    Pics of the E30!
    Papasmurf #3!! Oz10's Avatar
    If you lower your car a lot you will be riding on the bump stops. I'd recommend buying shorters shocks too.
    WillAgreeForReps!!
    The Town of Lula
    i've got some koni shocks. what do the h&r's go for? link?
    WillAgreeForReps!!
    The Town of Lula
    and what bout the bavarian autosports springs? i'm ordering a chip from them soon so if they r good i could get them together to save on shipping lol i dunno about how much it lowers it. it lowers it 30mm from stock. doesnt sound like much at all.
    WillAgreeForReps!!
    The Town of Lula
    and here's the only pic i have. i've got my rota c8's off my hatch in my sig on it now. i'm tuckin a little tire in the rear lmao
    All BMW's usually look lower in the rear.
    Not sure of the price on H&R, I am going with the race springs. Although I seriously have considered keeping these cut springs and going with some nice shocks. They really aren't bad.
    iTouge HillClimbGuy's Avatar
    snellville
    If you have been riding on cut springs for a while your shocks are gone. you will need to invest in some new shocks. if you do not want a bumpy ride.
    p.s the reason cut springs ruin shocks quick because since they tend to bounce they over work the shocks and cause them to go bad.
    Ballerness is like butter you just can't blob it in one place you got to spread that shit around
    emartu
    Lawrenceville, GA
    you'll probably want to roll some fenders, probably trim the inner fender if there is a stock one on those?...the stock suspension on the e30's has no adjustment for camber up front either, you can get back to spec camber tolerance with some offset front LCA bushings...got a set if you want
    the barvarians are good springs...probably just as stiff but not as low as the H&R's
    WillAgreeForReps!!
    The Town of Lula
    i'll look into the b&r's they seem to be very popular. and the shocks have been replaced with koni's that r in good condition
    Bender A. Rodriguez
    Macon
    I've got the H+R sport springs on mine. Rides nice but I want something a bit firmer since it sees a good bit of track time. I will tell you that if you lower it much over .5" in the rear you're going to need to take the subframe off and weld the adapters on to allow you to adjust the rear camber or it will be way off, so will your toe and there is no adjustment on the rear at all. The front camber is non adjustable unless you get camber plates, the offset CAB's will allow you to get more caster but won't get your camber right. I have the M3 offset urethane CABs and the M3 uppers and net about 2.3 degrees camber and about 6.8 degrees caster. The Konis aren't shorter in the front because they're just cartridges. Here's a pic of how mine sits on a set of 17"s. The ride height measured from the pinch rail is actually .25" higher in the rear but the E30's wheel wells are lower in the rear so the car will always look lower in the rear than it is. Unless you run some fairly low offset rims you won't need to roll the fenders.
    Ryan Reynolds
    Rallyist awestun's Avatar
    ⇦ Atlanta
    look at fk springs too. they have 75mm lowering springs.
    WillAgreeForReps!!
    The Town of Lula
    well i'm running a set of 15in rota c8's... IF i change wheels i'll just go with some lower offset 15s... the way my springs r cut now i'm sure i'm lower than a half inch under stock and the camber is pretty spot on... is there something i'm missing?
    Hey man I've got bavarian autosport springs on mine. They ride great on the street. Not as stiff as the others I'm sure. Heres a pic of my ride height...
    This was before I took out the spring pads in the rear. So it sits a little lower out back now.
    WillAgreeForReps!!
    The Town of Lula
    hey i posted on atlbimmer askin ya about your bavarian springs lol
    WillAgreeForReps!!
    The Town of Lula
    so its cool for the spring to be chillin out sittin on the flat bare metal plate on the bottom?
    Quote Originally Posted by roscoe View Post
    Yeah, some people say it squeaks a little more. mine does it from time to time. But it doesn't really bother me. I've heard that the spring can slip off the perch, but I've only heard of that happening once.
    WillAgreeForReps!!
    The Town of Lula
    yeah thats my main concern... although a friend of mine that bought Thighs e30 welded a thin piece of sheet metal to keep it centered and from slippin off the perch
    I haven't had any problems with it, and I'll admit I've done some ignant shit in that car.
    I rode in thighs e30 when he had. It's a nice ass e30 fo sho!
    emartu
    Lawrenceville, GA
    put the cushions under the spring!! i have 2 i will give you, think they are $6 from bmw?
    is there a reason guys take them out?? just that much lower?
    WillAgreeForReps!!
    The Town of Lula
    thanks for the info guys went with the bavarian springs should be here soon!! thanks for the pics especially to oz10
    Bender A. Rodriguez
    Macon
    Depending on the spring rubber you have its only going to lower it another 5mm if you take them out. Unless your shock is messed up its a limiter so I don't see the spring being able to come out even with the rubbers off. Personally I'd leave them in.
    Ryan Reynolds
