Thread: Power Steering Problem
    Default Power Steering Problem
    Hey,
    I have a 2003 accord and whenever I start the car up there seems to be a squeaky noise coming from the engine. It gets louder when you turn the wheel, and it is quieter when you are going straight. After driving the car for about 3-5 minutes the noise goes away completely. It isn't hard to turn the steering wheel or anything though. I was thinking it may be the power steering pump or something like that, but I don't know that much about the mechanics of how everything works so any help or advice would be helpful. Thanks!
    B-Town Crunk Force
    Statesboro, GA
    How does the power steering fluid level look?
    Quote Originally Posted by jdm>usdm View Post
    If the fluid is good might be the belt.
    So the fluid level was down a tiny bit so i refilled it all the way. After that the noise went away. Then 2 days later it came back and the power steering level is a tiny bit down again. Im gunna guess theres some sort of leak somewhere, but does anyone know any easy fixes?
    Also I just wanted to point out that only a tiny bit leaks out and then it wont leak again unless you refill it. Again thanks in advance.
Tags for this Thread
