Results 1 to 11 of 11
Thread: gauges
    Default gauges
    my brother integra gauge for the temp. is not working. any idea. its a 1993 integra.
    Canton
    very rarely is it actually the gauge more than likely it the coolant temp sensor or a wire.
    Try not. Do or Do not.
    where;s the sensor located at.
    Quote Originally Posted by eraser4g63
    Canton
    Not a clue i know jack shit about Hondas. but typically speaking near the thermostat. or on the side of the block.
    revolution big mac's Avatar
    It's down to the right from the dizzy a littlt near thermostat
    Canton
    See there ya go, I was close.
    haha thanks. so its most likely that sensor?
    i mean like the gauge temp. it doesnt move at all.
    Canton
    99% of the time yes. And chances are if it has not been replaced it needs to be, they are also fairly cheap. If it is not that it is going to be a wire issue.
    JohnBobAlingAdang 88NaCivic's Avatar
    Walton Cnty
    Wire going to the sensor is pulled off easy check for it
    aigh guys, will check when i get home. thanks. REPPED
