Results 1 to 4 of 4
Thread: venting the pcv (honda material)
    Project DX
    Default venting the pcv (honda material)
    set up is a single cam boost (nothing serious).. what do i need to do with my pcv i know its not good to keep it with the crankcase pressure. Should i disconnect everything for the pcv including the box ir what? i kno i should get a catch can but for the time being..
    DOHC NO-TEC
    known as Charles
    As long as you have a healthy motor then you will be fine leaving it the way it is stock. You will have some extra crackcase pressure but should not be that much unless you have a lot of blow by and then you have bigger problems. You can do a catch can but not always needed. You may want to change the PCV valve just to make sure it is working correctly.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    JDM TYTE AnthonyF's Avatar
    ^Like this gentleman said, you don't need a catch can, but It won't hurt to do one. Most people end up doing one anyways. I would go ahead and install one so you don't have to worry too much.
    -Ant.
    The Carbon Fibered R6
    Project DX
    i kno there are differnt set ups... what would be best to run on my setup... cause i checked it out just a few mins ago and i disconnected the hose that goes from the pcv to the crank chamber thingy and now that line is leaking a little bit of oil.. so im guessing i would run that hose to on part of the catch can, and the other from the valve cover?
    DOHC NO-TEC
