Results 1 to 23 of 23
Thread: Whats a good cam that makes top end power.
    Certified Gearhead NosVette's Avatar
    Default Whats a good cam that makes top end power.
    Im trying to see witch cam makes power on the high rpm range.All I see is hp and trq claims by people but by the way I look at it if you've got 10 hp more and your opponent and his rpm range goes 600rpm more its more likely that his car is going to out preform yours .I know that stage 1 cams(in general) and itr's powerband drops around 8600rpm.What I want is a cams that has a power band to 9200-9500rpm.Lmk what info you guys can give me.Thanks
    C5:Intake,Catback Exhaust,tuned,150shot MX3:exhaust,intake,klze swap,75 shot
    For got to mention its for a Honda B-series Vtec...
    your moms house
    what type os b series engine is it and is upgrading the valve train a option
    Quote Originally Posted by all-mota
    130,000 b16a2 with arp rod bolts and yes im upgrading the valve train still havent decided what brand im going with.I am going to go with a gsr head the fact of it because it will raise my compression.
    Out the game again!!
    southside of the border
    cant go wrong with skunk2 pro series. Also to big of a cam and not enough compression could result in a power lose.
    Soon!!
    Quote Originally Posted by allmotorX
    yeah I know...thats why I am going to put a gsr head and a thiner head gasket the stock b16a2 is 10:4
    West palm beach
    I appreciate you guys info but no one has answered my question yet about what cam has a power band all the way till 9200rpm-9500rpm
    Quote Originally Posted by NosVette
    Pretty much all depends on your setup in order to find that out you would have to experiment with different cams, or look around for different setups.
    Soon!!
    Texas
    Ive seen some crazy things!!!! My Ls/vtec setup needs some cams and I am undecided. I made 181/130... I saw a bone stock Type R (01) with a kid racing header and just a lil tune make 196-197. and then he put the pro 1s and made 201 and lost 1 in trq... I thought to myself 4-5hp over stock and a loss of 1 in trq?? is it worth 3-5hundred dollars for that. I just cant see my self paying that much for such a lil gain. BUT THEN AGAIN IT VARIES!!! TRIAL AN ERROR IS A BITCH!!!!! So with that being said good luck. Im just thinkin about doing ITR cams and call it day.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    I doubt you would even make power up with basically a stock c/r b16. Even though you're changing heads and using a thinner head gasket, the c/r gain is not significant. With that being said, I wouldn't get past a skunk2 stg2 cam unless you plan on building the bottom-end.
    okay I threw away my gsr head option and bought some brand new oem ctr pistons from my buddy im guessing my c/r will be good enough for a high rpm setup.Any info on the blox type c cams they look pretty good anybody tried them before?
    for what you are doing, nothing.
    B16s lack the airflow, compression, displacement to carry power that deep in the powerband.
    You would have to have a retarded ported head,big compression, big cam. Which in a b16 is pointless. Why do all that work to make 105ft/lbs of tQ.
    YOu need to tell us what you are trying to do first and what your goals are, but i can almost never think of a time to build a b16. They just arent worth it. Its a good starter motor, but its not something to build , never has been.
    I recommend the PRO Skunk camshafts, they have never done me wrong.
    Toda for what you pay and the power results, are junk.
    Buddy Club cams are decent
    Crower is garbage
    Texas
    Quote Originally Posted by Vteckidd
    Crower is garbage
    I didnt even throw you out like that... lol i didnt drop any names, thats why I stated DEPENDS ON SETUP!!!! You didnt have to come in here and throw your motor into the equation. I love you mike> NO HOMO...
    BTW I made 130 in TRQ with my b16. ............... Granted it was an LS/Vtec setup
    EF'N dirtragz's Avatar
    Jul 2009
    the ham
    Crower is garbage
    ^^^^^^pay attention for the words of the wise ^^^^^^
    88 crx hf lsvtec 153hp 117tq mainstream
    You always lose money chasin' hoes, but you never lose hoes chasin' money.
    Quote Originally Posted by Civichatch91 View Post
    I will never cheap out again...I should have known better
    Speical R
    Dec 2008
    you can also check on honda-tech..they have lots of info..
    your moms house
    alot of cams will make power into that range but the problem is wether the head and supporting mods will move enough air to make the power your wanting
    DC5-R
    Gwinett
    well if money is not an issue then I would go with Todas, they make good power from midrange all the way up top, but they won't make any power unless you're bumping atleast 12:1. My spec B's required a minimum of 11:1 to extract any power which still wasn't enough.
    Skunk2 pro's are a good choice also but still need compression to compensate for them. The supertech HD kit can handle just about any cam on the market and is a pretty decent price at around $400 for the whole setup.
    Why not change the b16 block out for a b18/b20? more displacement will help.
    So mucH bullshit in this thread lol
    college park
    mr honda speaks everyone listen
    *grabs notebook*
    now with LSD
    GWINNETT IS GREAT!
    i think you gain full benefits from header, intake and all that stuff from a fully built motor...
