Results 1 to 3 of 3
Thread: Camber Adjustment/Camber bolts question..
    ALL CAPS JITB's Avatar
    Default Camber Adjustment/Camber bolts question..
    My car has eccentric bolts to adjust the camber.. but its not enough to get it 100% corrected. Will aftermarket eccentric bolts make it so i can get it right? Or are the factory ones the max?
    known as Charles
    Some companies make aftermarket eccentric bolts that may have a little more adjustment in them. How close can you get with the factory ones? Some camber is ok as long as you don't have lots of toe in or toe out and crazy bump steer.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Quote Originally Posted by Main Stream
    i was told that i can get it almost correct with the stock one, but not 100%. But my tie rod ends were toast, so i waited onthe alignment.. but when i get them in the mail and put em on. Ill take care of it, and just cross my fingers that the stock bolt does it. but i got horrible wear.. i actually have tire shavings on my rear bumper, and in my rim...
