Results 1 to 31 of 31
Thread: Something tells me I won't ever have brake issues ever again....
    wherever
    Default Something tells me I won't ever have brake issues ever again....
    So I finally got them on the car. A friend of mine and I took about 2 hrs to put them on...taking our time to eat some pizza and whatnot in there too.
    Pedal effort is minimal for sure. But it's not the kinda of pedal feel like you get on crappy cars where you touch the brakes and eat a steeringwheel sandwich. It's the predictable linear kind and inspires confidence...in about 1" of pedal travel. Unfortunately I found out that the Brembo pads are much less aggressive than I thought..well, compared to the HP+ pads on the rear. Under braking from 90-0mph, I found it easy to lock the rears (also on shitty tires right now). This will probably change when I install the Poterfield RS-4 pads at all four corners. When I do, i'll update with how well they respond to a better pad setup. I'm not a huge fan of drilled rotors but the thermal capacity of this setup far exceeds anything that can be thrown at it, so the surface area lost isn't really a factor and if anything, the cross-drilling reduces some weight. I would get blanks or slotted, but Brembo doesn't have a replacement rotor for my application in anything other than drilled.
    Whole car shots will come after I wash the car today.
    Attached Thumbnails Attached Thumbnails -brembo2-jpg   -brembo-jpg   -brembo3-jpg
    02' Miata
    MYOB, Ga
    nice upgrade..
    GECKOSquad
    NIKOND7000 Shooter | flickr
    PURP-a-trader PURP's Avatar
    nice
    By far the nicest Miata I know of. You continue to do good work to that car.
    ALL CAPS JITB's Avatar
    u sure do know how to treat ur mazda well... it brings a tear to my eye..
    nice wheelz
    i luv u mike
    Senior Member sprix!'s Avatar
    Nice upgrade and write up.
    G37s 6MT/coupe
    IA Hater/Shit Talker
    Is this a conversion kit or a kit specifically designed for Miatas?
    is better than you..
    Somewhere you're not
    Nice upgrade... I will soon too have brembos on all 4 on the s15... just gotta find time between work and school to get em on...
    1010011010 Atlblkz06's Avatar
    Hell
    locking rear tires under hard braking - that sounds safe... do you have different pads up front?
    ASAP AssHole WTF?'s Avatar
    Woodstock/Kennesaw
    very nice
    wherever
    It's a kit specifically designed for the Miata. The thing about Brembo is that they have a selection of calipers that they sell, then all they do is make a hat and caliper bracket (two rather easy things to make) and bam! Gran Turismo Big Brake Kit for your car. The caliper (A-class caliper according to Brembo) is used on a far number of OE applications..some Ferrari rears, Volvo S60 front, Grand Cherokee SRT8 front among others.
    As for the rear lock-up, if you read slowly, you'd see that I pointed out that i have two different pad compounds front and rear right now..with the more aggressive pads being on the rear. I have ordered new pads for all four corners that should get rid of the problem
    02' Miata
    ATL represent
    if that doesn't help, you can always run a less agressive pad in the rear to compensate. I've found 'street' pads like hps work fine in the rear for track days - even if you have a very agressive pad up front, depending on what your bias is (obviously it's changed a lot due to the swept area increase up front).
    Something else you might want to look into is a bias controller. I know they can be a pain, but to fine tune I can't think of a better way to do it.
    GOON oneSLOWex's Avatar
    Chattanooga,TN
    NICE!!
    ...... amandDA's Avatar
    NE Boonies
    lol at eat a steering wheel sandwich!
    I have a prop. valve if you need one.
    Big brakes = ftw
    Just out of curiosity though what made you decide to go with cross drilled versus blanks?
    That car didn't even need a brake upgrade :p how much does it weigh?
    Looks good mike
    ..unknown
    Saw this car on Sunday. Pretty nice.
    Also, rotors appear to be one-piece?
    Watagatapitusberry ThE_EnD's Avatar
    Snellvegas
    looks real good, and i bet it feels alot better too. nh
    Hates streched tires DunDunSkeert's Avatar
    Misawa, Aomori, Japan
    Quote Originally Posted by swollix
    They are two-piece rotors, I saw them tonight and their ballin!!!!!
    wherever
    Big brakes = ftw
    It's the only rotor they use with the hat for the Miata application. They don't even have a blank/slotted replacement..so it's drilled only. If I had my choice, i'd go with slotted.
    02' Miata
    Turbo City USA
    Big brakes = ftw
    No selection for blanks,..... and the price he paid for these..
    so cliff's.. Mike, your an asshole for getting those at that price.
    wherever
    I know
    02' Miata
    so what did it cost?
    -IA MGMT is inappropriate.
    wherever
    coughcoughcoughtoofewhundredbuckscoughcough
    02' Miata
    wherever
    Quick pics on car. Lighting sucked so I over processed the pictured for the F of it.
    02' Miata
    Weekly Gwinnett/Junciton Meet
    nice setup mike, what size are the rotors?
    wherever
    12.5"
    02' Miata
    ☠gOOn☠ Brian*'s Avatar
    ☠Young Harris☠
    Best looking Miata I've ever seen!
