Results 1 to 11 of 11
Thread: Lots of 2.5 Rs parts some wrx/sti parts
    IA Member riddlinkidd6's Avatar
    Norcross
    Default Lots of 2.5 Rs parts some wrx/sti parts
    This is my garage:
    pictures can be found here:
    http://s5.photobucket.com/albums/y191/riddlinkidd66/
    only the first page of pictures
    I need this stuff gone.
    The '06 sti parts all have less than 2k miles on them
    the rs parts have anywhere from 1k-100k on them depending on the part, just ask.
    the wrx parts have less than 30k
    heres an inventory
    1998 RS passenger seat $5
    2006 STI dash support $10
    2006 white Rear sti bumper beam $10
    1998 red RS front bumper beam $10
    2006 white sti flat fuel door assembly $10
    2006 sti driver side rear window assembly:
    Glass: $25
    Window Motor: $60
    Regulator: $40
    sohc rs intake mani w/xs performance Fuel Pressure Regulator $30 PENDING
    sohc shortblock w/blown piston good for build $50
    sohc heads from blown motor, may need new valves, good for build $50 PENDING
    2003 wrx front and rear axles great shape. $25 each
    2006 Sti brakelines $5 (all four)
    2003 Wrx hubs w/knucles (rears and passenger front) $35 each
    2006 Sti engine crossmember $30
    2003 Wrx rear diff crossmember $15
    2006 Sti rear diff crossmember $15
    2006 Sti fuel lines (hardlines from gas tank to engine bay) $10
    Elbow fuel line $1
    2006 sti complete under dash heat/ac/fan assembly $40
    1998 stock rs catback $15
    2006 sti front swaybar with endlinks and bushings $10
    sti windshield wiper motor $5
    2000 rs sohc timing belt $10
    random:
    vacuum hoses offer
    rs ebrake $2
    exhaust hangers (2) $2
    o2 sensor harness $5
    accessory pulley $1 (a/c to crank)
    steel braided tubing (large diam) $1
    fuel line $1
    98 RS air box and maf (complete intake system) $15
    98 RS air box (just filter and box) $5
    STI air box (just filter and box) $5
    T’ed off heater hoses for turbo set up on an RS $5
    O2 exhaust sensors $5
    2000 rs Sohc spark plug wires with grounds $15
    2006 STI cross over water pipe $0
    RS Clutch and pressure plate $10
    RS Motor mounts $10
    2000 RS Sohc timing belt covers $15
    RS Radiator brackets $1
    Stock rs sideskirts painted red with some paint chips. need to be repainted. $40
    98 Rear rs seats $5
    Rs engine water pump $10
    Rs engine oil pump $10
    52mm center gauge pod $40
    2006 Sti hard lines (fuel) (under IM) $5
    2006 Sti turbo oil line $1
    2006 Sti steering column with ignition and keys $40
    2006 Sti a/c lines $15
    call me: 770 853 0191
    - Kevin
    EG33swap in progress
    Certified Gearhead atlxpat's Avatar
    atlanta
    any chance you got the stock intake silencer/snorkus?
    ಠ_ಠ XanRules's Avatar
    Dining in Hell
    where are you located? I'd like to come take a look.
    particularly interested in oil cap, catch can, grille, ebrake, intake manifold and braided tubing.
    Correct Fitment Crew CEO
    Because Only Turds Should be Dumped and Flushed.
    2012 Hyundai Veloster / 1960 Fiat 600D
    Norcross
    Quote Originally Posted by XanRules
    Located in Norcross/Duluth. The address is a duluth adress but its really in norcross. I would probably be able to meet up this weekend if you are available. maybe even thursday. PM me and let me know what works for you
    Quote Originally Posted by atlxpat
    And no I dont think i have that silencer/snorkus thing that you are talkin about
    Dining in Hell
    PM'ed.
    Bon'Qui Qui! osborne519's Avatar
    Carrollton, GA
    pmd i have cash
    ALL BUSINE$$ RedGTS's Avatar
    Cartersville
    I'll take the axels for the wrx? when and where can I come get them?
    1992 Acura NSX
    2014 Cadillac ATS
    2002 Z06
    2011 ZR1
    1969 Camaro Z28
    930 turbo
    2000 integra type r
    11
    Cartersville
    sti brakes lines too !!
    1992 Acura NSX
    2014 Cadillac ATS
    2002 Z06
    2011 ZR1
    1969 Camaro Z28
    930 turbo
    2000 integra type r
    11
    Certified Gearhead ghostrida3's Avatar
    snt you a pm
    Norcross
    I respond best to PM's rather than posts FYI to everyone.
    I still have the brake lines and the axles. just PM me or call me to schedule a time to meet. My number is 770-853-0191.
    Norcross
    updated
