Results 1 to 5 of 5
Thread: turn over problems after installing new clutch
    Unknown
    Aug 2009
    Default turn over problems after installing new clutch
    i have a 95 maxima with the stock engine, but i just switched the clutch to a stage 3 with a light weight flywheel, and some weak ass bolt ons like a cheap chip and a small electric supercharger that almost does nothing, i made sure all of the sensors was on the new intake pipes, and even switched some cam and crank sensors cuz thats what some assholes told me to. i am a beginning mechanic but i cant quite figure out what the problem is. is it from the upgrade?
    the car will not completely turn over, i have replaced the starter countlessly, alternator, battery and connections, the whole chargine system basically, for the starter to spin, and i have power, but it will not completely turn over, therefore i have to jump it in gear on a small hill.
    any insight will be GREATLY appreciated
    the poet,
    wrongtruth
    wont turn over completely???
    elibrate alittle more please
    AccuracyPerformanceAutomotive
    I think the cam and crank sensor is your problem, cant remeber which one. I had one that did the same thing. It would try hard to spin over but wouldnt, then it would backfire and crank up. The injector and ignition timing was all fucked up because the cam(or crank) sensor was bad.
    500whp of spinnin fury!!!
    Quote Originally Posted by QWK D16
    Guess you can't read huh.... He stated he already tried both of them....
    He just said he switched them...not replaced them with new ones. Cuz some asshole told him to. Just tryin to help...
