Thread: Turbo A Miata??
    Never In Control
    Sep 2008
    Alpharetta
    Default Turbo A Miata??
    Hey everyone, i was wondering what would be the best kit to use for a turbo application on a 97 miata. If you have ANY advice i would much appreciate it.
    known as Charles
    There are a couple different options you could go with. First is the tried and true Flyin Miata kits. These are very good, well designed and complete kits however a little pricey. Next you could do a custom kit with the Megasquirt PNP. This will give you more options to do the turbo kit the way you want. We have done some of both and they both work well.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Cumming, GA
    There are a TON of turbo Miata options...
    For some more specific Miata info try these:
    www.mx5atlanta.com
    www.clubroadster.net
    www.miataturbo.net
    And, by ALL means, talk to shops like Mainstream that have worked on these cars!! Forums are forums....real shops are the people who make your turbo car run.
    One Curve At A Time
    Mx5 is a bit more friendly than the other two IMO.
    97 DX Civic w/ H22 FS
    Sure as long as you don't say anything as a joke...
    Build your own kit, cheaper, and run the MS PNP.
    Bender A. Rodriguez
    Macon
    If you don't have any knowledge or good fab skills its easier to buy the Voodoo kit from FM or one of the kits from Begi. Both work great on limited boost but neither will make lots of power because the MAF runs out of resolution quickly on the NA's. Once you switch to a MAP based system you can run over 240whp with a good tune on the stock engine. I too have done a few miata's down here and run a 400whp NB all the time.
    Ryan Reynolds
    iTrack matthewAPM's Avatar
    Otto-Flimm-Straße, Nürburg
    Flyin Miata
    Matthew Brueck
    iTrack Motorsports
    www.itrackms.com
    Canton
    Build your own.
    Try not. Do or Do not.
    Miata OG Roadster's Avatar
    Covington/Decatur
    LS1 or Windsor swap, forget the snail. You'll be wanting more within a couple months unless you over-do it to start with.
