Thread: B series build
    IFUKSWITYA
    Spankys Speed Fab
    Red face B series build
    maybe yall can shine some light my direction
    i have heard alot about people using a GSR block with LS crank and pistons
    i heard it has longer stroke
    if this was a good idea i was gonna try that with CTR pistons and a GSR head
    please give opinions
    im begging for help
    Quote Originally Posted by Superslow95
    im begging for help
    I've just about got all my stuff together for my other gsr. I've got an Ls crank and rods with pr3 pistons, CTR would be too high compression for the most part. I believe you may have to bend the oil squirters to clear the pistons since they come down slightly further. I've got a lot of good toys for it, but since it is my dd hatch, I'm not getting too crazy with it, my other hatch is for that...
    IFUKSWITYA
    Spankys Speed Fab
    Default bump
    thank i appreciate your opinion and advice
    anyone else
    your moms house
    yes you can do it but i would stay away from the ctr pistons you can make just as much power with jdm b16 pistons or type r's. you also do have to bend the oil squirters out of the way or just remove them all together and plug the holes
    IFUKSWITYA
    Spankys Speed Fab
    Default bump
    thanks
    ok lets say i do a B16 block crank and rods with CTR pistons and a worked GSR head am i gonna run into any clearance issues there
    hates all of you.... Crimson[b16]'s Avatar
    thanks
    c speed racings website has a good compression calculator. check that out so you can make sure you can run pump gas
    Nuh Botha Mi chameleon30038's Avatar
    Gaza Mi Seh
    golden eagle makes oil squirter plugs.....so they got ya covered in that regards
