Results 1 to 29 of 29
Thread: tapping noise
    Default tapping noise
    i have an LS and it's making a tapping noise...would that be a stuck lifter or something else? it doesn't do it all the time...sometimes it taps loud and sometimes it's a little softer...did valve adjustment and added lucas oil stabilizer and still having the same issue...could someone tell me what they think the problem might be or what i can do to fix it?
    West palm beach
    did the valve adjustment change it at all ?
    knocking!
    Bottom end is shot!!
    Lifters??
    West palm beach
    I doubt its the bottom end, he says it doesn't do it all the time..
    Quote Originally Posted by punkr6
    no it didnt change it at all
    West palm beach
    does it change with rpm's ?
    Guess you never heard one calm down after it warms up then>???
    Also sometimes if its a small knock it will tap louder when cold then less when its warm , and sometimes you can rev it up pass a certain RPM and it will be less noise also....
    I still say its a KNOCK!
    WHat work was perform before this problem?
    Head work?
    Cams?
    or did it just start on its own?
    ALso have you listen to it under the car???
    Is it louder under the car or on top of the motor?
    If on top , take the valve cover and see if a rocker arm is broke but if this was the case it would idle werd and run like a misfire
    West palm beach
    yea, I agree, but i'm being optimistic
    Optimistic your ass somewhere else Freak!!!
    I
    K
    I
    D
    Head work?
    Cams?
    No work....stock head...just started on its own... never listened to it under the car though...
    West palm beach
    I
    K
    I
    D
    just saying..
    Infidels!!!!!
    Quote Originally Posted by eLuSiv3egT
    can you record it and youtube it for us?
    West palm beach
    LOL,
    LOL,
    West palm beach
    it would help to know if it coming from the top or bottom...
    Does the Engine have enough oil in it?:
    West palm beach
    been drinking again ?
    West palm beach
    is someone trapped in the trunk ?
    Yea!!
    and no but I bet that monkey in in the trunk!!!
    Norcross
    my engine does this too. it will make a tapping sound, like click click click click.. then nothing for a second or two. then click again. etc. ive always thot it was my valves maybe? would the engine still run strong if it were knocking? cause my car still pulls pretty hard
    Quote Originally Posted by j0nbunklah0m
    Make your own thread and stop hijacking others lol
    Norcross
    lol but its on topic! can i get an answer?
    coming from the top
    yes...plenty
    How does it run?
    Jul 2009
    How does it run?
    "picture yourself naked running backwards through a cornfield holding hands with kimbo slice high on crack cocain, qualudes, and pcp in 102 degree heat."
    im just sayin
    i vote knock
