Thread: DIY MBC?
    B-Town Crunk Force
    Statesboro, GA
    Default DIY MBC?
    So Ive read tons of information on the ball and spring type manual boost controller. But what Im having a hard time finding information on is another type of DYI boost controlling. Im not sure what exactely its called. But Ive heard that plastic valves designed for small engines or something like that can be used. Theyre similar in design to how an irrigation pipe that runs water through it would be. As in to allow water to flow through the pipe, a valve would be turned which the handle runs parallel to the pipe letting the water flow freely. And turning the handle at a 45 degree angle would only allow half of the water to flow through.
    Can this same principal be used for controlling boost? And what is this called? The "bleeder type valve"?
    turbos
    CI motorsports sell a good piece forr like $15 bucks i have been running it for a couple months with no prob other than keep myself from wanting to turn the boost up more
    TOO BIG
    530TQ + FWD = FAIL!! Kason23's Avatar
    Rockmart
    I have a turboxs for sale. Its a bleed type and came off my old setup.
    Neon PoWa
    Now Delta 46 equipped
    432whp/425wtq on lower boost
    B-Town Crunk Force
    Statesboro, GA
    Well I actually have a hallman mbc on the way. I was just wanting one for tonight so I could run it at the drag strip.
    I tried out that ghetto valve thing I heard about. Didnt work for shit.lol
    Jul 2009
    an aquarium fish tank bleeder valve....
    about a 1.25 at walmart.......
    Rockmart
    There is a how-to on the internet to make a Home depot one for like 12 bucks. You can also use a plastic tee with a pin hole in it to bleed boost
    Neon PoWa
    TT kte324's Avatar
    Oct 2008
    Columbus, GA
    I made one from some stuff at lowe's but in the end its cheaper to get one off ebay for like ten bucks, and looks better.
    Southern Speed
    Macon
    Get you a box of different size plastic T's and see which one puts the PSI where you want it
    IA's Pedo-cord tdurr's Avatar
    Fayco
    ^^ lol best idea ever.
    Save ur engines!
