Results 1 to 40 of 57
Thread: .:Easy Bitch Pin Removal:.
    roberta
    Default .:Easy Bitch Pin Removal:.
    So today i figured that i would show you guys a way of gettin the bitch pin out,that works for me. First your gonna need a couple of tools(c-clamp,allen head bit,and a 9mm deep well socket...make sure the bit on the allen head fits inside the pin.
    well lets get started by puttin the allen bit inside the pin
    you can see where mine is just sittin inside.
    the socket is used for pressure and to guide the bit as you can see in this pic
    tighten the c clamp until the very top of the allen head is exposed so you can retrieve it and the bottom of the pin will be exposed once you remove the(bit,clamp,socket)
    you will next grab a pair of viscrips and pull that bitch out
    now the bitch is out and your linkage is free.
    hope this help you guys in the future
    Privateer Racing!!
    Duluth,Ga
    Thats the hard way man. Use a AC compressor bolt, put it inside and knock the pin out. Super easy and fast... Nice write up tough
    roberta
    yea just tryin to help folks out,this only takes a minute and some people may not have those kind of resources.
    Your mom's bed
    very nice, nice and simple. i just bought the special tool off the Snapon on truck. lol
    college park
    find me a easier way to do it with the swap IN the car lol nice write up tho
    now with LSD
    Southside
    That's not Peter's tranny is it lol
    what time is lunch?
    woodstock
    I use a 8mm punch and just wack it.
    I have never done one outside the car.
    If you have a c-clamp weld a small rod on to the foot then it is easy.
    I've used the punch and also a spare ac bolt.
    All while laying under the car.
    http://www.performanceforum.com/wesv...tch/bitch.html
    Go to http://matcotools.com/ and search for this part number: MST6455
    aye bro .:Stirfry:.'s Avatar
    lol yea it is..
    but good stuff josh
    ATL DAsquad Member #9
    roberta
    Quote Originally Posted by EJ1soSlo
    yes sir it is
    roberta
    you can use the same process under the car with the swap in
    Stang Mod slostang's Avatar
    Southside
    i always used a small center punch to knock that sum bish out.
    Quote Originally Posted by 00CelicaGT
    I was about to say the same thing, its only like $15. And mated to an impact hammer...
    roberta
    just tryin to help people out i know there are other ways to do it i just showed the way i use if people do not have access to those things
    Northwest Georgia
    10mm bolt and a hammer is how i do it.
    Warner robins ,Ga
    Quote Originally Posted by SPOOLIN
    same.
    I get mine out with a guardrail...
    Just sayin'.
    Senior Member WalkS's Avatar
    Middle Ga
    nice write up! I just use a bolt that I find in my garage, and bang it out...simple and it works every time!
    JJSPEC Racing
    roberta
    Quote Originally Posted by WalkS
    thanks man!i just did it like this after i broke 2 punchs and a screwdriver
    It's all about JDM.
    CA to GA
    you can also use an air hammer (if you have air compressor available.)
    i use a 12mm bolt thats flat on the end... so i dont damage the pin
    Ohio asshole.
    I use a broken 1/4 drive extension. Works perfectly.
    i use a 3/16 deep socket and hammer it out no problem, been using the same bolt 6-7 swaps now 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    I ♥ s2
    hawaii
    middle ga
    i have a ton a a/c bolts if anyone is interested in buy a bitch pin removal tool...lol
    my momma's house
    How do you get it back in?
    Trend settin'
    Loganville
    Roll pin punch is all you need, but this is a good write up for using what you got laying around
    Ballin' on a Budget
    roberta
    Quote Originally Posted by carbon_crash
    thanks and thats all im tryin to do...help people out i know everybody has there methods this is just one that i use
    roberta
    Quote Originally Posted by TheChosenOne
    get the linkage and everything lined up and put the pin in and for me one hit with a hammer and it goes in
    SOUTHSIDE
    i use the header bolt the one with the spring and hammer it out.....it work perfect every time
    what time is lunch?
    woodstock
    pair of channel locks for me. Get it lined up then gently squeeze the channel locks.
    Project Cx Underway
    Columbus, GA
    nice. I always used a screwdriver and a hammer.
    93 cx-project
    12 Mazdaspeed 3-daily
    07 R6- toy
    Southside
    Quote Originally Posted by p3tey2
    believe it or not the massive oil across the entire tranny is was really gave it away
    Quote Originally Posted by B18c1Turboed
    The best, cheapest, easyiest way right thur. Since those AC bolts have that large chamfered point they just slide right in. I modified one so that it actually has the same OD as the pins ID so it works even better.
    Southside Ridin HATCH
    Nice man
    roberta
    ^thanks man
    Middle, Ga
    Damn, ya boy takes some good pic's. Haha. Nice write up though, Josh.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    roberta
    ^yea you did ok and thanks bro.
    South Side Georgia
    I use the 12mm bolt on the exhaust that hold the header and cat together. 12mm and a buefy hammer.
    resize pic
    HONDA RIDIN LOW BOY
    i dunno if u have much room to do that under the car
    roberta
    Quote Originally Posted by VTECxRoCKz
    if your car is on jack stands there is plenty....trust me ive done it before
