Thread: B18
    Default B18
    how do you gain hp and tq from a ls? B18B1. nonvtec or boost or spray.
    time for the build! jerseyef9's Avatar
    SOUTHSIDE
    i was told you can build the head
    R.I.P Booga
    M.A.P
    F.D.L.R
    more details?
    Quote Originally Posted by jerseyef9
    SOUTHSIDE
    get the port and polish, valve job, bigger cams
    R.I.P Booga
    M.A.P
    F.D.L.R
    any more info on the valve job? also, wat you mean by port and polish.also, will Gsr cams and B16 cams fit?
    SOUTHSIDE
    all this work is mostly done a machine shop
    those are vtec cam
    you need non vtec cam
    crower make great cam for your motor
    R.I.P Booga
    M.A.P
    F.D.L.R
    Southside of The Jungle
    Quote Originally Posted by hmong_Spec
    Nope gsr cams or b16 cams wont work.and valve job you can take it to any machine shop and get a 3angle valve job.Its when they cut the valve seats to increase smoother air flow.Alot of people on here will tell you dont waste your time but check out nonvtec.com they are ls enthuasiat and have alot of info about how to get power out of them which cams to use and other jubaloop.
    3angle valve job
    http://www.team-integra.net/images/B...levalves03.jpg
