Results 1 to 26 of 26
Thread: what gauages are you running?
    04 Civic SI
    Ga
    Default what gauages are you running?
    so im about to install my turbo and i am in need of gauges and was wondering what all gauages are people running on there cars and how are they working? brand,type ETC...
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    if you can afford them, defi's are gonna be one of the better options. they can datalog, peak recall, warnings, the whole nine yards
    Who knows?
    Whore for the AWD LordZed's Avatar
    Marietta, GA
    you need a boost guage, wide band AF guage, and a FPR. You can also run an EGT guage if your feeling froggy. Brands just depend on your taste, just dont go too cheepo
    Suffolk, VA
    FPR? you mean a fuel pressure gauge? i'm gonna say a oil pressure gauge would be first over that. the most common setups i see include boost, oil pressure, and a wideband A/F. you can include fuel pressure, oil temp, and EGT as well, as they all are important parameters to monitor.
    Who knows?
    04 Civic SI
    Ga
    ok sooo whats good resonable price brands? i know the aem uego wideband is the best wideband you can get for the price and its 200$ well so ive heard...but for boost and oil pressure which i figured were my other 2 whaat are good priced brands? autometer?
    Marietta, GA
    Quote Originally Posted by Identity_Crisis
    well I ment a fuel pressure regulator, but yeah were talking guages. Oil pressure as well, forgot about that one. but you gott tune that fuel pressure or your gonna hate life
    Suffolk, VA
    Quote Originally Posted by LordZed
    yeah but generally an adjustable fuel pressure regulator has a gauge on it, it's a set and forget item. he was asking about just gauges.
    Who knows?
    Privateer Racing!!
    Duluth,Ga
    I run Oil presure , water temp , A/f and tach. Everything else i just look at the data log. Thats for my drag car.
    On my street i just run oil and a/f and boost. No need to really have more.
    Marietta, GA
    This is true The Aeromotive ones are good
    Certified Gearhead miro_gt's Avatar
    wideband and boost gauge is all you need.
    then put tire pressure, humidity, and girlfriend mood gauges
    No need for a fpr on an ep... its returnless
    dc5
    ATL, GA
    Thumbs up
    Quote Originally Posted by patch515
    You have an ep3? If so, no need for any gauges. Kpro with your laptop is your gauges a/f, boost, voltage, water, iat, knock level, knock count, tps, load, cam angle, and etc...
    Where Am I
    I've always ran autometer gauges
    Canton
    All you need is a boost gauge. If you would like to purchase an A/F ratio gauge ( wide band) I would recommend one(Though I do not have one). If you get it tuned properly ( IE-Dyno) then you should be alright.
    Try not. Do or Do not.
    140 on one wheel
    columbus, ga
    wideband,boost gauge,oil pessure gauge and my lap top
    Marietta, GA
    Quote Originally Posted by Bruce Leroy
    EP? I could act like I know, but then I wont learn anything Im sure once you say it I'll know exactly what your talking about
    EP3 is his chassis code. His car, like most newer hondas, have a returnless style fuel system, so there is no way to hook up a fpr..... Unless he converts to a return style system. Which isnt to hard to do. but usually not necessary unless you are going big.
    Marietta, GA
    I was thinking thats what it ment, thanks! Im not well versed in Honda speak per say
    boost gauge and narrowband a/f (basically worthless, it came with the car), that's it. one of these days i will swap the narrowband out for an oil pressure gauge tho. those 2 are the only ones you really NEED in a boosted car IMO once it's tuned.
    Ohio asshole.
    I ran an Autometer boost gauge. Chipped the ECU myself. Ran a downloaded tune which was mildly close to my set up. Threw in an NGK AFX wideband. Street tuned it with a friends lap top.
    Ran 14psi on my B20. The motor still runs I just don't have it anymore.
    Nordic Sled cjhutch's Avatar
    I'm using a ScanGauge II that I currently have for sale. *Shameless plug* it monitors what your OBD sends out so for me I'm reading boost, IAT, Oil Pressure, and Short Term Fuel Trim. I'm switching to a laptop setup in order to store information and review full run playback. It's more expensive, but it's what I want.
    Back from R&D Land
    Back from R&D Land
    boost, oil, fuel pressure and wideband in my car.
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    AEM Wideband, Glowshift Boost, Dakota Digital Oil pressure. Soon to have Emange Ultimate for storing info btw.
    04 Civic SI
    Ga
    thanks for all in the info guy...im figuring the aem wideband although i hate the price...and srti boost and oil pressure...now i have to find the pod to hold them i really dont want the long one across the side i want something on my dash or somewere but cant find one anywere for my car.
    Marietta, GA
    See if the WRX dash pod's will work. Also, JC Whitney had universal dash pod's IIRC
    TT kte324's Avatar
    Oct 2008
    Columbus, GA
    The most important gauges, I think, is a wideband and boost gauge. I use plx.
