Results 1 to 15 of 15
Thread: Over heating.
    Default Over heating.
    My civic has a overheating problem.
    I blead the radiator.
    The water goes into the reservoir tank and starts spilling out.
    I took out the thermostat and it's still doing the same thing.
    I'm gonna buy an oem one tomorrow and replace it.
    And the fans comes on.
    Any ideas on what else could help?
    Also could it be the water pump? If so what are the signs of a bad water pump?
    water pump
    Well tomorrow i'm going to change my head gasket, water pump, Thermostat and timing belt.
    Should this fix my problem or could there be other things wrong?
    AccuracyPerformanceAutomotive
    Quote Originally Posted by Arm&hammer
    Sounds like a headgasket problem if its pushing the water back into the res.
    500whp of spinnin fury!!!
    JJSPEC Racing
    Quote Originally Posted by QWK D16
    same thing i was thinking.....that's when i knew to change my headgasket on my old eg, it would start spewing coolant into the engine bay, lol
    -2001 Lexus IS300
    somewhere, GA
    ^^yup...i had an old sentra and everytime you turned the A/C it would pop the headgasket and then my coolant resevoir would turn into 'OL faithful...went through 3 before i figured it out....I was 16
    '82 TE72 SR5 Sport Coupe
    3tc
    Thanks a lot guys.
    I didn't have time to change my head gasket today but I'm defiantly going to change it tomorrow.
    JJSPEC Racing
    good luck with it man!
    -2001 Lexus IS300
    No more over heating!!!!
    somewhere, GA
    I would rep you, but it wont let me!
    3tc
    wat was the reaason.
    Brings da fuckn heat Lurker's Avatar
    Aug 2009
    on the phone
    head gasket?
    head gasket and radiator cap.
    IA Member JDM_H's Avatar
    L'ville, GA
    thanks yo this thread helped alot
