Results 1 to 37 of 37
Thread: FS: HONDATA FULL-RACE ITR GSR B16 MOTORS HEADS GT3076R LSD HKS GREDDY TIAL WISECO ARP
    Default FS: HONDATA FULL-RACE ITR GSR B16 MOTORS HEADS GT3076R LSD HKS GREDDY TIAL WISECO ARP
    PLEASE READ EVERYTHING BEFORE ASKING QUESTIONS! I AM LOCATED IN SOUTH CAROLINA- PICKUP IS WELCOME OR I CAN SHIP. DONT PM ME ASKING ME WHERE IM AT!
    Location: Fort Mill sc (Charlotte Area), and Clemson SC
    Contact: [email protected], PM me, or 803 389 3047
    Cash, or a possible trade
    I AM IN THE MARKET FOR:
    ·Jeep Cherokee 5 speed 4.0 4x4
    ·Any diesel truck (manual only)
    I have a HUGE stock pile of parts laying around that I would like to get rid of. This time I finally think I’m done. Im in the market for a reliable Jeep Cherokee 4.0 4x4 5 speed- let me know if you have one you would like to sell or possibly trade some parts for-
    Prices are for pickup- I have no problem shipping though, and am paypal verified/ an ebay power seller with TONS of vouches.
    OBO!
    1.Rota Slip Streams spoon copys $500
    Great shape, minus one being a slightly different wheel… you cant tell from 5 feet unless you stare
    Tires are 205 55 15, and starting to show their age in the front- rears are great
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/yooo035.jpg[/IMG]
    2.Half core civic radiator with slim fan $60
    Has B series hoses already attached
    Slim fan that worked great on a turbo GSR
    3.B series OBD1 GSR Distributor $100
    Great shape dizzy fits all b series VTEC motors
    OEM Honda
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/moreparts024.jpg[/IMg]
    4.P72 Integra GSR Rod $25 (2 available)
    Piston has cracked ringlands
    No spun bearings
    5.1995 Hydraulic GSR transmission $550
    Came from a STOCK low mileage GSR that was wrecked
    Purchased from Eric (Agent Smith)- was told it had no grinds, and I trust him
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/stufomgz128.jpg[/IMG]
    6.1995 Integra GSR Shift linkage $100
    Perfect for EG EK swaps
    Comes with shifter as well great shape!
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/moreparts013.jpg[/IMg]
    7.1995 Integra GSR Axles $75
    Came from a running car
    One axle has 5k on it
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/yooo048.jpg[/IMG]
    8.1995 Integra GSR B series Mounts $45
    Driver size, and passenger side
    No rear mount
    9.Clutch Master cylinder/ slave cylinder $35
    Brand new stuff
    10.B series VTEC solenoid $75
    From my personal build
    11.GSR Camshafts $75
    12.GSR Valve cover $60
    Stripped, and went through parts wash
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow002.jpg[/IMG]
    13.ARP Head studs $120
    For GSR, LSV, B20v etc
    BRAND NEW
    14.FRESH GSR BLOCK
    0 miles on it
    EVERY single nut and bolt is included and bagged for easy assembly
    Matching main caps, rear main seal carrier, etc included!
    All work performed by Lynch in Greenville
    Bored .50 over, cleaned, decked, bead blasted, perfect!
    When bored, it was bored for 35 wall clearance (BOOST) when used with the wiseco pistons im selling
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow023.jpg[/IMG]
    15.Wiseco 81.5mm pistons $450, 375 with block!
    For above block brand new
    Rings file fitted for above block
    Low compression (9.5ish in GSR block with LS crank)
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow038.jpg[/IMG]
    16.LS Crankshaft $125
    Fresh from machine shop
    Micropolished, magnafluxed, cleaned, micd, balance checked
    Still in bag from Lynch’s machine shop
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow015.jpg[/IMG]
    17.GSR Oil pan $75
    Went through parts washer , slight ding doesn’t affect anything
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow010.jpg[/IMG]
    18.GSR Oil Cooler $100
    Same as used on ITR
    Complete
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/stufomgz144.jpg[/IMG]
    19.ACL Bearings- for GSR block with LS crank $50
    NEW
    $50
    20.ITR Fuel Rail $50
    Flows more fuel
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/itr002.jpg[/IMG]
    21.1995 Integra GSR Tranny $750
    I will GAURENTEE there are no grinds
    BEST I HAVE EVER FELT!
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/moreparts001.jpg[/IMG]
    22.Oil Feed line/Return line setup $50
    Don’t use junk lines!
    Top notch quality!
    23.Garrett GT3076R $950
    2500 miles
    Shaft place, as expected from a ball bearing turbo without coolant or oil in it
    Made 420whp on 13 pounds in a BUILT motor and 500 on higher boost!
    Includes cooling lines!
    Best turbo for a 500 whp car!
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow076.jpg[/IMG]
    24.GM 3 bar map sensor $65
    With pig tail
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow058.jpg[/IMG]
    25.LS Transmission HYDRO $950
    I purchased this from a guy that had a FULLY built badass integra- it has:
    OBX LSD
    Fully rebuilt 2500 miles ago
    New input shaft bearing
    NO GRINDS
    $950
    26.REV industries Turbo setup $800
    SUPER high quality stuff! ( same as full-race, neukin, synapse, RLD etc)
    Flanged for T3 non AC 38mm Tial
    Includes 3” downpipe, dumptube as well!
    Made 420whp with said GT30R
    27.Full-Race Motorsports manifold setup $1000
    Jet Hot coated manifold
    3” downpipe looks rough, but doesn’t leak
    Clears EF/DA cross members
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/fullrace003.jpg[/IMG]
    28.Tial 38mm WG $175
    Great shape!
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow073.jpg[/IMG]
    29.Tial 40mm WG $200
    15psi spring
    Great shape
    30.HKS 50mm WG $300
    Unknown spring
    BADASS RARE WG!
    31.Hytech Manifold $1000
    100% Race design
    Twin scroll
    50mm WG flange
    T4 inlet
    Originally cost $3000
    32.Competition Clutch Stage 5 $150
    2500 miles
    Showing some wear on the disc
    New disc is 100 from CC
    Holds well into 600whp range!
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow056.jpg[/IMG]
    33.OBD2a-OBD1 harness $65
    Perfect for 96+ integra civic etc
    Bought from XENOCRON
    New!
    34.Tapped LS oil pan $50
    -10AN bung
    Good shape
    35.ARP LS Head studs $75
    Good shape 100% complete
    36.Chipped P72 $150
    Has spoon program I was told
    37.Vacuum manifold $30
    Good shape
    Golden Eagle brand
    38.Greddy Cooling plate $60
    Fits 94+ integra
    Definitely helps- I have read on forums where people logged 10* less coolant temps
    RARE
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/Tonsofpartswow071.jpg[/IMG]
    39.98+ integra ALL RED tail lights
    Slight crack (have piece and can be glued back on
    $100 plus your stock tails
    40.Short ram for integra civic etc $25
    41.LS Valvecover $20
    OBD0/1 style
    Painted red
    [IMG]http://i82.photobucket.com/albums/j276/jessetoedtman/fullrace019.jpg[/IMG]
    42.OBD1 LS Distributor $65
    Came from running boosted integra
    43.LS Head $35
    Good shape
    Recent valvejob
    CHEAP
    44.1995 Integra GSR Oil pump $20
    Great shape
    For an additional $20 I can shim it to ITR spec for more oil pressure
    45.OEM 1995 Integra GSR Throttle body $50
    OEM all sensors included
    Perfect for your swap!
    46.OEM 1995 Integra GSR Intake manifold $100
    100% complete
    All sensors included
    Great shape!
    47.92+ Civic D series shift linkage $25
    Fits many more
    Cheap as hell
    48.OEM GSR Exhaust manifold $35
    Few scratches dents etc
    From 95 spec integra
    49.GSR Hondata Intake manifold gasket $35
    Used for low mileage
    50.1999 Civic SI B16A2 PR3 Head $350 FIRM!
    Looks to be in pretty good shape
    Head, cams, gears only
    No vtec solenoid
    Tapped for LSVTEC
    51.81.5MM ITR P73 pistons $70
    Brand new with rings/wrist pins etc
    52.B series/ H series Knock sensor $50
    Great shape
    I heart fat girls tinkolby_25's Avatar
    Jacksonville/Centre, AL
    bump for a hell of alot of good parts
    whole lotta shit!
    slingshot sales ceo. ls-r teg's Avatar
    gwinnett
    u sure those wheels are rotas? look like drags 2 me..
    STILLHAVE THAT PENIS ?????
    They should have never gave u niggggas vtec
    ballin on a budget hondalover00's Avatar
    ga
    interested in ls head studs....pm me sir
    aye bro .:Stirfry:.'s Avatar
    good stuff my man:.
    glws yo
    ATL DAsquad Member #9
    Lots and lots of turbo stuff, glws.
    vanilla sky.
    look like slips to me/
    southside ATL
    i want the gsr acl bearings, and the Oil Feed line/Return line setup. Send me pics cause ur links dont work.
    CASH IN HAND, for paypal..
    Whats next? lcortes32's Avatar
    Dec 2008
    Atlanta/SO*CAL/Nashville
    hey im interested in the pistons pm me cash in hand...
    93 Civic EX - Current
    95 Acura Integra GSR-Traded
    99 civic ex-Traded
    95 Civic EG DX Hatch -Traded
    96 Civic DX Coupe -Tradded
    98 Civic EX Fo' Do' -R.I.P
    93 Civic Si Hatchback (Miss you so much Buddy)
    93 Acura DA9 (R.I.P)
    97 Civic EK Coupe(tradded)
    97 Accord SE (traded)
    Everyone has been PMd
    I was told they are rota slips when I purchased- either way there both essentially identical knock offs lol
    N/A POWAH! Gorilla Eg!'s Avatar
    that hi-tech mani IS FAWKING AMAZING!!!!
    PMs replied to, just for everyones knowledge- Clemson SC is off exit 19 in South Carolina off 85. Its roughly 1.5 hours away from yall
    Tuck'd & Swap'd Thundercat's Avatar
    Valdosta
    ~CREW LEGIT~IMPORTALLIANCE.ORG~All IN FAB~BISIMOTO
    gwinnett
    rotas have a little groove inbetween the spokes...hard to explain
    but it looks like 1 rota and 3 drags...mite jus b pix.
    Quote Originally Posted by silverDA
    rotas & drags real or fake! thats what they usually go for any ways. And GL on selling these baddass Parts. Great parts are being sold at hard times nowadays, and folks like me need a job to make ends meet haha GL again on the sales.
    /Oo ___A___ oO\
    |=_/_______\_=|
    One of them has that said groove- so maybe you are right. Regardless as Vick said its the going price-
    pending turbo sale
    *NY Driver* CeOTiO8's Avatar
    In your girl
    Damn bump for alot of parts.... Might need that LS head with GSR manifold lmk a price with it shipped please
    PROUD SUPPORTER OF BAM-TECH WTF?
    sorry the LS head sold
    bumo for a hella good parts!!! GL bro!
    damn, i want that penis
    up top more stuff is selling!
    up top
    jesse you have pm..
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Valdosta
    good prompt seller
    slick fricks sikfricks's Avatar
    ROME,GA
    that manifold is badass wish i had the cash
    <img src=http://www.importatlanta.com/forums/image.php?type=sigpic&userid=19661&dateline=1274467236 border=0 alt= />
    Where Am I
    Lots of good parts. GLWS......
    thanks yall
    in my house
    hey. will you sell parts off the gsr manifold or i have to buy the hole thing?
    Pmd
    up toppp
    Tons of stuff sold I need to update this thread!
    lotta stuff guys!
    in my house
    clear your pm's...................
    Jonesboro/Stockbridge
    Quote Originally Posted by b20civic08 View Post
    bump for sh!t loads of good parts
    lol old thread dude. check dates..
    Senior Member cm7k24's Avatar
    kennesaw
    man you've always got some damn good stuff for sale.
