Results 1 to 14 of 14
Thread: OBD2 Civic GSR swap
    South Side Georgia
    Default OBD2 Civic GSR swap
    Ok i need to know what exactly need to be done to drop in a Obd1 gsr swap in a bd2 civic.
    I know that the harness of the civic will have to be put on the Gsr motor. But will the be plugs missing? Are there going to be CEL's? Emissions?
    Also the Distributor and alternator will be need to changed or converted OBD2 for a fact. The mounts or get get the brackets.
    Whats else?? I've never dont a swap on a 1996+ civic and just trying to help out a friend. Thanks IA
    resize pic
    West palm beach
    use the obd2 dizzy, injectors,and ecu. Also the obd2 oil pump and crank sensor thats behind the lower timing belt cover will need to be added. Other then that its pretty straight foward. lucky for you you have both set ups and its just a matter of swaping some parts around...
    NO ADVERTISING
    -IA MANAGEMENT
    SOUTHSIDE
    have jdmda9 help you out
    West palm beach
    I'm on the southside, let me know if you need anything...
    NO ADVERTISING
    -IA MANAGEMENT
    You will need to do the Crank angle sensor MOD...
    Civic uses a 3 pin plug, and GSR uses a 2 pin plug...
    Quote Originally Posted by wrekonize
    Neggative.... Either a sponsor or he will get banned
    Quote Originally Posted by punkr6
    be careful
    West palm beach
    be careful
    I retrack my last statement, I was only trying to help a neighbor out completly FREE and I was in no way trying to solicitate labor. Jesus....
    NO ADVERTISING
    -IA MANAGEMENT
    SOUTHSIDE
    this post was a joke tech5
    because these two been at each others necks about who know more about swaps.....lol
    im just trying to clear jdmda9 name hes a good friend of mine....
    Thats going to be hard to do my friend
    thats right because i know more.
    Than a Rock I agree
    known as Charles
    As for swapping in a OBD1 gsr in an OBD2 civic here is what you will need to do. You will use the wiring harness that came in the car and just modify it to the new motor.
    If civic is EX and already has vtec then you will not have to add those.
    If civic is Y7 then you will have to convert to 2 wire IAC.
    You can use the OBD1 dizzy ust rewire/repin the plug for dizzy.
    You can use the OBD1 ecu with conversion harness but if stock ecu you will have to add knock sensor wiring and butterfly box wiring if using stock intake manifold.
    Alt plug can be rewired.
    Will have to use ODB2 GSR ecu (2000-2001 have emobilizers and will not work) to pass emissions and will have to do the CKF rewire at ecu and not have to change oil pumps.
    Good luck with swap.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Certified Gearhead jdmda9's Avatar
    exactly. hopefully its an ex so that the swap will be less of a hassle. later!
    Quote Originally Posted by Main Stream
    shhh...
    vtec game scArY. . !
