Results 1 to 19 of 19
Thread: Integra wont start :/
    B Powered Mik2006's Avatar
    North Side
    Default Integra wont start :/
    well to sum it all off i pulled spark plug number 1 while the engine was on and it was idleing for about 5 seconds then it just died compleatly and never started agian. then i saw on cyn 4 that there was oil from a bad valve cover gasket and i replaced that. now i changed the spark plug wires, distributor, distributor rotor, and tested the ignition coil. i changed the spark plug wires about 2 weeks ago. im stumpped and its pissing me off.
    and i checked the main relay and its not that. anyone know?
    cars
    integra 90 ls
    integra 92 gsr b20v turbo
    integra 00 ls
    infiniti i35 02
    North Side
    oh yah and i sprayed starter fluid in threw the manifold and it still dosent work
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
    AccuracyPerformanceAutomotive
    Quote Originally Posted by Mik2006
    Then its def. a spark issue. Need 2 see if the rotor button is good. Some of the aftermarket rotor buttons arent designed well and the spark runs back down and grounds to the distributor.
    500whp of spinnin fury!!!
    turbos
    did you check compression...... sound to me like you may have jumped time.
    Start by checking compression
    TOO BIG
    If you need some help with it give us a call 678-363-6789 mainstreamperformance.
    Sounds like an ignition issue from the sound of it.
    iTouge HillClimbGuy's Avatar
    snellville
    More than likely you brunt out the coil
    How did you test it?
    It is very common to burn out the ignition coil by either doing a spark test or load test. When you remove the resistance of the spark plug out of the system you create a short and ohm law states that electricity is lazy it will take the shortest path so you “burn a hole in the coil” by causing this short.
    Replace the coil and if every thing else is installed correctly then it should fire up
    Even with no compassion with starter fluid if should at least pop a little when you turn it over
    Ballerness is like butter you just can't blob it in one place you got to spread that shit around
    no photo skills....
    Jul 2009
    senoia
    i'm going to say the coil 2... but i always thought it was a part that worked. or didn't
    North Side
    i tested the coil by useing a gsr coil. and i used a volt metter on the 2 and the both got 12.0/1. are gsr and ls coils the same?
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
    North Side
    ok well i just swaped out the whole dizzy with my friends dizzy from his ls and it still dosent work.
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
    hmm ignition coil, cap, rotor button, timing, might have jumped timing but taking off one spark plug wire wont make this happen though, cause i Done this procedure plenty of times and it dont cause this problem of yours. Do you have enough gas ? 8D
    CHECK:
    spark plugs wires in correct order?
    timing
    dizzy cap
    /Oo ___A___ oO\
    |=_/_______\_=|
    Chickens Eat Eggs
    south side hoe
    i was gonna say it might have burn the little igniter in the distruntor but try changing the spark pluggs itself check or if u have gas in the car i dunno lol,if not shit im stumped too ..hope it doesnt have to do with your fuel pumps and shitt o yeah check your timing belt it might have broke i dunno jus trying to help
    athens
    ur not outta gas are you?
    North Side
    naw i gotta half tank of gas, plus i sprayed the engine starter stuff trew the intake and still no crank. only things i can think of now is the alarm or ecu.
    the wires are definitely in order.
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
    LAWRENCEVILLE
    check for spark. sounds like you blew the coil
    Hella stock member!
    athens
    well uv gone through teh dizzy..hav u tried changing out the plug wires? check the connectors on the wiring harness (not the ones on the dizzy)to see if you get a voltage reading.
    athens
    ahh..u already chnged th wires..
    heres smthn anyway
    i dunno about yours..but on my integra, its set up like this.
    if youre standing in front of the car. from left to right the cylinder order is 4,3,2,1...soo..shortest wire to #4..longest to #1
    Quote Originally Posted by chip P.
    Attached Thumbnails Attached Thumbnails -untitled-jpg
    North Side
    appreciate the help everyone, i found out the problem was inside the intake manifold a valve was stuck closed. its up and working agian. now i just gotta do the timing.
    glad i dident need scooby dooo for this case.
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
    athens
    gahhh..thts soo obvious..shoulda gottn tht sooner. good job tho
    North Side
    man the first thing i was gonna check out till i started asking people. but it was just weired that it wasent sucking in the starter fluid hard at all.
    cars
    integra 90 ls
    integra 00 ls
    infiniti i35 02
