Results 1 to 24 of 24
Thread: motor reving itself to 6 grand
    05srt4
    Jun 2009
    Upatoi, Georgia, United States
    Default motor reving itself to 6 grand
    ight so i swapped throttle bodies on my d15b and started the car up it is was idleing at 6 grand. the throttle as completely shut, and the cable was at the perfect placement. i put the stock throttle body back on and still did it. even the idle screw was backed all the way out, can someone help me please!
    AccuracyPerformanceAutomotive
    Quote Originally Posted by smart_ion
    Check the gasket, I think I had one a while back that the gasket was wrong and caused an internal vacuum leak.
    500whp of spinnin fury!!!
    05srt4
    Jun 2009
    the gasket between the body and intake right
    Yep, i think there are a couple different cut-outs of the same gasket between each model car.
    Daytona Beach
    Check your engine on how it revs before you check a motor.
    05srt4
    Jun 2009
    well it was idiling perfect. right under 1 grand. then this shit happens.
    check for one of your vacuum lines being unplugged... common mistake
    Da Nastyist Whipz Member #9
    05srt4
    Jun 2009
    i did. all of them are in
    put your hand over the throttle body covering it. If it idles down to normal then you have a vacuum leak.
    If the engine shuts off, you have NO vacuum leaks.
    Usually when you replace a TB, its a vacuum leak, you either ripped the TB to manifold gasket, put it on wrong, or forgot to hook up a vacuum line
    05srt4
    Jun 2009
    ight, ill try everything yall are tellin me tomorrow. im so confused about it
    JDM TYTE AnthonyF's Avatar
    Like everyone stated, I'm pretty sure you tore your TB gasket or isn't instaleld correctly.
    -Ant.
    The Carbon Fibered R6
    Where Am I
    Quote Originally Posted by Vteckidd
    x2^ easiest way to do it
    05srt4
    Jun 2009
    fixed it. now i just think i gota vacuum leak cuz it revs good then revs up, then down. back and forth revving
    Woodstock, Ga
    idle air control valve maybe bad also..
    I would bet along the lines of an extreme vac leak, stuck tb or cable.
    Woodstock, Ga
    throttle cable clip come out of the fire wall and get hung up lol seen it happen.
    known as Charles
    Try adjusting the idle screw in or out some. If not then do what Mike said and put you hand over the TB to see if motor shuts off. If it does then you have a bad IAC, if not then vac leak.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    no photo skills....
    Jul 2009
    senoia
    IAC sounds like its bad... or gasket...
    fast idle valve
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
    Newnan
    make sure all the vaccum hoses are hooked up
    05srt4
    Jun 2009
    ight thanks yall. got it runnin good. now another prob ...i have no power at all. like i let go of the clutch and all and it just dies. and yes i kno how to drive a stick, used to have a rx-8
    wheres the VAN!!
    Jun 2009
    beat its a vac leak..sucka.lol
    Make sure ur vacuum line to the MAP sensor is on and good.
    05srt4
    Jun 2009
    idk thats it or not, maybe cuz its a lame 4-spd...?? lol
