Results 1 to 17 of 17
Thread: T/W,F/T 91 B13 se-r....with mods and turbo
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    Default T/W,F/T 91 B13 se-r....with mods and turbo
    car is gone
    Make:Nissan
    Model:Sentra se-r classic
    Year:1991
    Mileage:220xxx on chassis, 50xxx(documented) on motor,15xxx(documented) on tranny and clutch
    Options:base, no sunroof, manual windows
    Mods:see below
    Engine:Euro sr20de 10:1
    VIN#:1n4gb32a6mc812xxx
    Condition:mechanically great, cosmetically......well you can see below
    Price:T/w......so $1
    Alright Guys......I got rid of my beloved yet highly expensive Impulse RS for this car, but now I need something with more room. This car use to be NissanEgg's(Nissan Tech in AL), and I traded my rare Impulse RS for it. I love this car but I need some more room. I am highly interested in an early G20 with similar mods. This car is a great car and has been well taken care of(I have a full book of reciepts to verify this) other than what I have listed below. I have religously changed the oil and maintained it the short time that i have owned it. The ONLY REASON I AM WANTING SOMETHING ELSE IS BECAUSE I NEED SOMETHING ELSE. IF you think that I might be interested in what you have, lmk. Although I still am partial to DSM, I really don't need one, so don't tempt me lol.I may, or may not be interested in something else. I am quite content with the cars driveability and this is more of a testing water thread. Please read the following......Thanks in Advance
    ENGINE
    -UK SR20DE 10.0:1 compression from 1998 Nissan Primera GT
    -cold air intake system with K&N filter
    -Infiniti G20 distributor
    -Prothane motor mounts
    -new Nissan crossmember bushings
    EXHAUST
    -stainless steel 4-2-1 header
    -2.5" test pipe
    -old skool ancient Greddy SP catback exhaust
    TRANSMISSION
    -Maxima pressure plate
    -Nismo B13 SE-R clutch disc
    -rebuilt tranny with new 5th gear/synchro assemblies, shift forks, and seals by nissan master mechanic
    -Nissan updated clutch cable
    -factory VLSD with 4.18 final drive, wanna go with the 4.44 gear set
    -Prothane transmission mounts
    -adjustable short throw shifter
    -Nismo leather shift knob
    SUSPENSION
    -KYB AGX struts front and rear
    -Eibach Sportline springs
    -Energy Suspension Master hyper flex bushing kit
    -Summit front strut bar
    BRAKES
    -1993 Nissan NX2000 AD22VF front brake system
    MISC
    -1998 Nissan Sentra SE-L "titanium" colored wheels
    -2003 Nissan Tsuru front headlamps and turn signals
    -2003 Nissan Tsuru front grille and headlight filler pieces
    -2003 Nissan Tsuru tail lamps
    -2003 Nissan Tsuru badges
    -2003 Nissan Tsuru floormats front and rear
    -1992 Nissan Tsuru GSR2000 white face gauges
    -1994 Nissan Sentra SE-R trunk tail lamps
    -1993 Nissan NX2000 black center console with arm rest
    -"NISSAN" fog light covers from the WD22 Xterras
    -Greddy 52mm pearl white elctronic fuel and oil pressure gauges
    -Lotek 2-pod A-pillar trim
    -ancient Pioneer CD player
    -Sony Xplode front door speakers
    -Pioneer rear deck speakers
    Also has a FULL COMPLETE, turbo kit with everything that you need, this is a turbo kit from a BlueBird JDM sr20det and has fuel rail and injectors, all oil lines, intercooler and piping, t25 turbo with no shaft play and already installed on the manifold, downpipe, o2 sensor, adjustable fuel pressure regulator and lines, all couplers, etc. This kit is good for this motor because you can run 7 lbs all day long and have great response from the motor. Many people have ran this motor with this setup and say that it is quite a blast. Currently the motor makes 152whp all motor. I HAVE ALL RECEIPTS FOR ANYTHING DONE TO THIS CAR!!!!!! This motor with this turbo kit.......will spin the tires through 3rd gear. Higher compression and small turbo = alot of fun at low boost levels(i.e. turbo b18c1).
    Also recently installed new front CV axles, front rotors and pads, new rear pads and resurfaced rear rotors, balanced tires, new alternator , new fuel rail and injector o-rings, and new reverse and neutral switches , and new ac compressor pulley bearing and new alternator belt.
    The Bad:
    The car was hit by a drunk guy a while ago on the drivers side. I have pulled most of the dents and prepped it but the door will need to be replaced, although it is not bad at all. I have pulled and primered the drivers side quarter panel, but needs to be finished alittle more, looks alot better than it did. The door is $35 dollars from Pull-a-part(Southeast salvage yard) and there are over 25 of the sentras there to pull from in Atlanta! The interior is not perfect but it is clean, complete, and functional. The header rattles on start up but quits immediately after. The A/C belt fell off a couple of days ago, so I haven't put one back on it(I had a shorter belt in the trunk). The A/C was ICE cold before that.
    ############UPDATED#############
    first pic is of the new door.....its not perfect but its a ton better. I have the trim peice in the trunk, just haven't put it on yet
    North_Side_Nissans Sunny_B13's Avatar
    Northside GA
    GL bump..seems like everyone is selling their se-r now
    N/A B13
    SpeeD Merchants IdeaL HachiRockU's Avatar
    bump glws
    Gardendale AL
    Quote Originally Posted by Sunny_B13
    I won't be selling it.....frankly because I don't need the money........I will probably just keep it but thought that i would through it out there. I will be going to pullapart tomorow in Birmingham and grab a door. They have 9 sentras to choose from there. If i do that, I will most likely keep it, the car runs flawlessly and handles awesome, unless i get an offer that I can't refuse
    Gardendale AL
    now has newer door, its not perfect but its a ton better. Ill add pix
    North Augusta, SC
    Errr... I want this car. I miss my b13 se-r.
    Back to being stock and slow
    Middle, Ga
    Trade? GLWS, brosky.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Gardendale AL
    Do you have something for trade or are you talking about Motivation?lol
    He hit me up on another forum also. I wish the GSX was running!
    I would have kept the RS personally. But not a bad SE-R. Good luck with the sale.
    Garage-Sixgun
    North Augusta, SC
    Quote Originally Posted by highspeed
    If the GSX was running I wouldn't want to trade it for anything.
    Alright, I'll hit ya up on gadsm.
    nismo_92
    atlanta
    BUMP FOR A SER OWER I HAVE ONE TO...
    WILLING TO SELL THE TURBO KIT?
    OR B14 WHEELS?
    TRDyang nismo_b14's Avatar
    wanna part out the b14 wheels?
    Gardendale AL
    no part out, car will stay complete. might be getting rid of it soon for another clean VR4
    Gardendale AL
    new pix, I taped off the car and primered it to look good......or better at least, Ill post the new pix
    Gardendale AL
    oh and I am opening all trades, that way I have some to choose from. Next week I will be sending the ecu to be chipped for the turbo kit, and when I do that I will be keeping if for sure. Texting is the best way to get ahold of me
    FULTON COUNTY GA & TUSCALOOSA AL
    ANY TRADE ,200SX SER 1996
    Gardendale AL
    car is gone
