Thread: E85!! Why or Why Not!!
    In GA; Missing NJ
    Wink E85!! Why or Why Not!!
    i am in the process of building a or 2.0L gsr motor. i am going for 550 to 600whp. it is not a daily driver.. but i was thinking about e85... what you guys think... i know that i am need more fun to run e85 with high horsepower cars.. or should i just run race gas or water/methonal....
    Back from R&D Land
    Back from R&D Land
    E85 is fine, just make sure you have the fuel system to handle it. What is your setup?
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    In GA; Missing NJ
    gsr block with darton sleeves..
    ls crank
    eagle rods
    weisco 85mm pistons
    b16 head
    supertech valves
    skunk 2 pro series valve springs
    skunk 2 retainers
    gsr cams for right
    not sure on my turbo yet.. i was thinking about the precision billiet 6265 turbo..
    #1 availability. good luck finding it at a random gas station if you street the car.
    #2 make sure your ENTIRE fuel system is prepped for e85.. its highy corrosive and eats typical rubber lines etc. Need to make sure everything in your car is e85 safe including fuel pump, all lines and even your injectors/o-rings and everything in between.
    #3 tune. iirc, it takes 33% more e85 to produce the equivalent power as gasoline, meaning your injectors have got to be much larger than would typically required for your power goals with gasoline. plus larger injectors can sometimes cause idle problems but really depends on your tune.
    If i were to want to run e85 i would most def have a ems that allows for dual maps so i could switch to 93octane if i had to in a jam.
    Back from R&D Land
    Back from R&D Land
    Quote Originally Posted by civic-r11
    ls crank
    eagle rods
    weisco 85mm pistons
    b16 head
    supertech valves
    skunk 2 retainers
    gsr cams for right
    What are you using for your fuel system?
    www.JKOBD.com
    Dead or alive WANTED's Avatar
    For modern automobiles, I don't agree with this being as great a concern. There are a few guys who have been running it religiously without issue for quite some time now.
    The bigger concern is having enough injector space. You will need to run 30% more fuel than you would.
    On the flipside, you can run some fairly aggressive timing as e85 is pretty knock resistant.
    A couple of issues to be wary of though. First, the injectors tend to "gum up" over time. The theory is that it has to do with the quality of the fuel itself. Some is just dirtier than others.
    The other issue is oil contamination. Because you have to run 30% more than 91oct, it has been known to make your oil smell sweet. This is not good. To counter this, you will need to change your oil and filter a little more frequently.
    "Horsepower is no substitute for brains, fuckers."
    Sure flex fuel vehicles are fine with e85, but any car that a b-series engine is going in is going to have an older style fuel system. If i were building a 500+whp car, i would make absolutely sure im not going to have a fueling issue caused by this. Its to cheap to replace the fuel system compared to running lean or having a leak.
    CA18FTMFL BITCH!!!! JBalla1036's Avatar
    Alpharetta
    You can run rubber lines, just make sure they are new and not old and cracked. And from what I have been told by ppl who run e85 they say you should run synthetic oil instead of conventional. Btw there are 10 gas stations in Ga that carry E85. http://zilvia.net/f/tech-talk/250353...setup-e85.html
    In GA; Missing NJ
    Quote Originally Posted by JKOBD
    Hondata s300
    In GA; Missing NJ
    Quote Originally Posted by JBalla1036
    There are actually more. Than that in ga
    Sneaker Freak Repiks's Avatar
    Jun 2009
    Well.
    As said before, good luck finding it.
    And you're either going to suffer huge drops in power to maintain the same gas mileage, or pump a lot more fuel through to make more power.
    Not really worth it IMO.
    03' Lightning w/ Bolt-Ons | KLR 650 | Duece.
    Back from R&D Land
    Back from R&D Land
    Hondata s300
    That is your engine management. Now what about fuel system? You want to make 550-600whp on E85, what are you going to use for pump(s), injectors, lines, etc.?
    www.JKOBD.com
