Results 1 to 29 of 29
Thread: ::TPS Issues and failure symptoms::
    my momma's house
    Default ::TPS Issues and failure symptoms::
    To make a long story short, I had a TPS CEL for a while (more than 4 months) in my d15b7 with no real issues. I took my car to a shop and had the turbo kit installed, and on the way home the car was "bucking" or cutting in and out of power while I was in partial throttle. If I stepped on it a bit, the power would snap back on cue with turbo spool.... . I did not beat on the car. Never went past 5k on the rpm's. I was merely trying to make it home.
    30 minutes later... I have a whole in my block.... or two...
    DO YOU SEE THAT!!! No more than, stopping at the QT on Jimmy Carter, filling up on 93, and then blowing up after I past Pleasant Hill on 85. TPS???
    Now, here is my new engine. Compliments to Josh (Tech5)
    I would hate to see my new motor end up like my last one, so I'm asking if the TPS could have been the culprit, or am I on the wrong trail? Also, Blox has an aftermarket TPS that I can buy on Ebay. has any one ran this before? If so, any issues?
    Trend settin'
    Back from R&D Land
    Back from R&D Land
    Seriously, why the hell would you drive the car around bucking and running like crap with a TPS code for months?
    Did the shop install the turbo kit and not fix the TPS issues? That's crazy.
    www.JKOBD.com
    00 Civic Street Car V2 coming soon
    my momma's house
    Quote Originally Posted by JKOBD
    ... You FAIL at reading. I said the car had a code when it was all motor, but ran FINE. Not until the turbo kit was on did the car start acting sporadic. And to be clear, it was a friend of mines shop, and he intalled everything perfectly, I just didn't have another TPS. He said that it should have blown up for that reason. I asked Scotty, and he said the same thing.
    Trend settin'
    my momma's house
    I know someone knows somethin...
    Trend settin'
    Back from R&D Land
    Back from R&D Land
    Quote Originally Posted by TheChosenOne
    ... Not until the turbo kit was on did the car start acting sporadic. And to be clear, it was a friend of mines shop, and he intalled everything perfectly, I just didn't have another TPS. He said that it should have blown up for that reason. I asked Scotty, and he said the same thing.
    So they installed the turbo kit and didn't fix the code? Did you get it tuned or what engine management was this on?
    www.JKOBD.com
    www.jjspec.com Macon, Ga
    X2 what engine management do you have?
    I have to say the tune may have contributed to the hole in the block. TPS is important, but it is only part of the pic. An overly lean condition will cause bucking, hesitation and other issues as well as engine damage. Def get that TPS fixed for sure before riding out with it again.
    my momma's house
    The only time I drove the car boosted, was back from the shop 2 my house. I was running a chipped P28 from Scotty, and I called him first after it blew and assured me that it had 2 be the TPS... I was going to get the car dyno tuned at Mainstream, but I couldn't even make it home.
    Trend settin'
    WORD
    you seem to have the worst luck, but you bring it on yourself.
    Fix the TPS issue, and if the car WASNT TUNED, and you had a TPS issue, thats why it blew the fuck up
    an ECU is a BASEMAP, its not a license to go beating the shit out of the car.
    You went in boost, with a broken TPS, you blew your engine. Lesson learned hopefully
    Do you know what a TPS does or how it works? Read up on it and you will see why your motor blew up
    my momma's house
    Quote Originally Posted by Vteckidd
    I NEVER said I beat on the car! I drove it from the shop to my house. Yes, I know what a TPS does, and I knew that it was faulty, but I was assured that my car shouldn't blow up because of it. I'm not trying to cheap out and make it on a basemap. I know I have to get the car tuned, and I will. I'm just trying to make sure I have pin-pointed the issue before I go through this again.
    ...no one has answered my question about the Blox TPS.
    Thanks for all the help.
    Trend settin'
    Yeah its a 4 door
    i just installed a BLOX map sensor, because my tps was faulty as well, very nice item (BLOX TPS)
    my momma's house
    Quote Originally Posted by CB7tuner
    Thanks man! Your the only person so far, who knows how to answer the OP's question in a post! REPS! Plus, I was reading on HondaTech and there were mixed reviews. Did you put it on, or did you have someone else install it?
    Trend settin'
    West palm beach
    This is why you lost the engine
    NO ADVERTISING
    -IA MANAGEMENT
    Yeah its a 4 door
    i installed it myself, all you need is a multi-meter..... theres 3 wires on the tps sensor plug, tap into the middle wire with the positive side of the multimeter (your doing this with the plug still plugged into the new tps sensor and installed onto the throttle body), and ground the other multimeter wire to a ground. turn your ignition on the second click (the one where your fuel pump comes on but your motor isnt cranked) leave it on, now with the throttle closed/at rest the tps sensor should read between .45 - .50 volts (if not adjust it by slightly spinning the sensor) and then at WOT the TPS should read 5 volts. hope that helps
    West palm beach
    Josh loves silver spray paint
    NO ADVERTISING
    -IA MANAGEMENT
    we have all answered your question. You just dont want to hear the answer.
    A TPS , in conjunction with your Map sensor, tells your ECU how much fuel, timing you need. You may have been fine on just the MAP sensor before, but the fact that you installed a turbo kit that was untuned, and drove it WITHOUT FIXING THE EXISTING PROBLEM kinda shows that you have no idea what you are doing. No offense.
    If you know what a TPS is then you should know the consequences of riding around on a bad one.
    Unless you had a T15 turbo on it, you stated you hit boost. That means you were at least around 4000-5000 rpms on that 1.5L motor. No turbo builds boost at idle. Any amount of positive manifold pressure, combined with a faulty TPS makes for an easy diagnosis for why your motor blew up.
    The BLOX TPS should fix your problem ,if the TPS sensor itself is bad. Why dont you try fixing it instead of throwing parts at it. All you have to do is use a volt meter to see if its working properly.
    You were kinda insinuating that Scotty or maybe the shop had something to do with your motor blowing up. I was telling you that an ECU is a basemap, and YES it is totally possible with a broken TPS for you to blow your motor up that fast.
    From the looks of your block it detonated pretty bad, and most likely that motor was on its way out anyway. That just doesnt happen from putting around town.
    FYI a D15B7s redline is around 6800, so you doing "ONLY 5000 RPMS" is deep in its powerband. So next time either fix the issue or dont drive it
    go figure, the engineers at honda design a CEL for a faulty sensor and it actually means something. NO WAY!
    So if your oil pressure light comes on, and it runs fine, are you going to keep going? then when your motor locks up are you going to make a thread about "HEY MY OIL PRESSURE LIGHT CAME ON AND MY MOTOR LOCKED UP, BUT IT RAN FINE BEFORE, COULD THAT BE THE PROBLEM>?"
    Usually if a CEL comes on, there is a problem that needs to be fixed
    roflcopter V-Spec II
    Norcross
    Your question has been answered 100 times. How the hell is it a good idea to run a NA-T motor without a THROTTLE POSITION SENSOR? Think about that. Who cares that it ran fine before you TURBOCHARGED it?
    my momma's house
    Thanks for all your help, but your sarcasm is really becoming counterproductive at this point. I understand im a ricer for trying to get my car home with a CEL... shame on me. I NEVER put any blame on Scotty or my friends shop. All I wanted to know was if there could possibly be any more contruibuting factors. I'm no master mechanic, or some Honda genius, I have a thorough but general understanding about my car, and I just wanted some positive input.
    I'm definantly a boost noob, but I've done an asss of research, so cut me a phuckin break. "Fix your TPS before you boost it again"... I got it. I'm not trying to be a douchebag, so chill out. I just want to get my car running and tuned before school starts.
    Trend settin'
    Dude, your car had a TPS CEL for MONTHS. YOu never fixed the problem. Then you put a TURBO on it, and it blew up while you were hitting 5000rpms and the turbo was "boostin"
    So this "i drove home with a cel and im a ricer shame on me" is bullshit.
    There is no other contributing factor unless your motor was on its way out anyway, but even then a TPS CEL needs to be fixed regardless or motor condition.
    Your sarcasm and the little smilies you were using kinda hinted that you were trying to place blame on someone else IMO
    my momma's house
    Ok. My fault Vteckidd... didn't mean to disrespect you.
    Well, I'm just gunna replace the TPS, and go from there. But just for future reference, don't be so condecending. It's been a tough summer for me, and all I want to do is finish my car. Actually, I think this was your old car before. But anyway, the motor had 200k on it, so it was passed its prime; tommorow is a new day/engine.
    I may not do everything the right way, but I'm tryin, soooo. yea. . Oh yea, since I'm an un-employed nihilistic threat, I had 2 much free time... this is what I get for trying to do everything myself. ... you win some and you lose some. I've got the motor out without the help of any of my fellow IA friends...
    Trend settin'
    Not being condescending, just giving you some tough "love" lol
    If you are going to do something like this, make sure you do it right, otherwise, you end up in the predicament you are in.
    The TPS problem, 200K+ engine, turbo, all spells disaster.
    Good luck on this motor
    West palm beach
    [b]f. ... you win some and you lose some. I've got the motor out without the help of any of my fellow IA friends...
    I would have helped you bro. If you need anything Holla...
    NO ADVERTISING
    -IA MANAGEMENT
    Back from R&D Land
    Back from R&D Land
    Haha. The law has been laid down after I stepped out.
    As far as the TPS, have you confirmed your old one is bad? I have not used the blox TPS so I can't help there, but the TPS in itself is a simple circuit so hopefully they can't screw it up too bad.
    www.JKOBD.com
    my momma's house
    Haha. The law has been laid down after I stepped out...
    ...who are you talking to?
    Trend settin'
    Duluth, GA
    Shoulda called me.
    p.s. You have all my tools and my jack. So technically you got a lot of help from me.
    Wirkz
    damn that sux.... gl with the new one though
    UN!QU3 CR3@T!0N$ JP - In memory of John
    Yum-Yum Racing
    Quit being a fucking douche. He asked a simple question he did not come herwe for bashing . He came here hoping someone on IA might have a little more knowledge than himself and would help him fix his issue. This is the exact reason why IA is going Downhill when you have A bitch ass fucking faggott running shops and shit
