Results 1 to 18 of 18
Thread: 96 Altima tranny issue(s)
    Old Noobie shadnox's Avatar
    Dahlonega
    Default 96 Altima tranny issue(s)
    Ok, I have an 96 manual Altima that's giving me some major problems all of a sudden. I just flushed the old gear oil, and replaced it. 4 days later I suddenly lose reverse, third gear doesn't like to go in half the time, and 5th seems to pop out while driving at low RPM's.
    Any help that anybody can give me would be awesome.
    Dahlonega
    Not sure if it'll help with an answer, but the engine is the KA24DE.
    Jul 2009
    I have the same car, just a 1993. Clutch problems FTL.
    Dahlonega
    I doubt its the clutch, my brother and I replaced it less than a year ago.
    To eleborate on when it went out, I had to drive to Dahlonega from Athens, I stopped at a gas station and it worked fine about 20 miles out, but when I got to Dahlonega, I tried to pull out and it simply wouldn't go into reverse. I waited over night to let it cool, no change. No leaks from the tranny, no leaking oil, etc. the cars been through a lot but I can't think of any peticular reason for it start acting up.
    Alpharetta, Ga
    you need a tranny.... or you can take that one apart and try to rebuild it. but that is harder than it sounds. because nissan likes to have all the gear hubs and bearing surfaces pressed on. which usually means youll break one or two when pressing them off. and currently you dont know whats wrong with the inside.. and im sure to replace half of the internals will be well more than double a used transmission will be.
    The G Spot Hero
    is it bad that all I saw was that you had tranny issues and thought man that sucks.... literally
    Certified Gearhead Shift_2WIN's Avatar
    Jul 2009
    Downtown Atl
    Have u ever changed the gear oil b4 or is this the 1st time? And how many miles are on the car? If u have gone way too long without changing the gear oil, then ive heard u shouldnt change it out as thats the only thing keeping you tranny 2gether. All of the metal particles in the fluid that usually u want out, are now whats creating the fiction needed 4 your transmission to shift. Once those fluids are removed and replaced with fresh particle free fluid, then there is no longer any type of friction, and the transmission jus slips. Ive also heard dat is u have gone to long without changing it, some transmission shops will not change it. You should take it to a transmission shop, and let them take a look.
    Jul 2009
    Downtown Atl
    Alpharetta, Ga
    Quote Originally Posted by Shift_2WIN
    wow congraualtions giving advice on a automatic transmission. a 96 altima doesnt have a 5spd auto. but it does have a 5spd manual... read a little more.
    but your right though about the automatic... if you wait to long... then dont change it. but with manuals you can change it and be fine. he has more issues than just fluid when you loose gears.
    The G Spot Hero
    'Round These Parts
    I was actually thinkin' of changing the gear oil in my 96, I just reconsidered. LoL
    Damn, Manuals shouldn't act like Autos in terms of fluid sensitivity.
    Leisa and S. 4 Life NM?
    Alpharetta, Ga
    yeah and manuals dont slip because of fluid.
    The G Spot Hero
    'Round These Parts
    I got a 93 LSD Tranny swapped into my 96 after the Tranny failed for the second time.
    first time @ 75k valve body failure (Rebuilt @ Dealer)
    second time @ 196k same deal
    Manual Conversion with new OEM clutch, hope it lasts.
    Quote Originally Posted by DownSouthGB
    not clutch bad tranny
    Dahlonega
    Well, not the kind of happy news I was hoping for. Thanks for the information though. I'll never buy any automatic after reading this.
    'Round These Parts
    I just bought a 95 SE 5 speed for parts, let me know if you need the tranny.
    Drives Soooo Well, You can drive it before you buy it. I just need someone to but the engine as well. Car is SOLID! Clutch replaced 2 months ago. 155k with personal maint records since new.
    Dahlonega
    I'll think about it for a later date, but I'm looking at getting a different vehicle completely. I've had this poor thing for 5 years now and I'd like to get something that looks better. Mine is very dinged up.
    Jul 2009
    Quote Originally Posted by shadnox
    No, I was saying mine had clutch problems lol.
    Jul 2009
    Nah, my clutch went out. I changed it last week.
