HOW TO SET VALVE ON INTEGRA LS HEAD
				 INTEGRA LS
 INTEGRA LS
				How to set valve clearance? Or install valves?
www.helminc.com
www.JKOBD.com
00 Civic Street Car V2 coming soon
				Need more info, and turn off caps please.
Better watch your back...before you get the NINJA SLAP
				You have to take the head off to install valves.Originally Posted by JKOBD
If you are talking about valve clearance then you loosen the nut on the rocker use a feeler gauge and a screwdriver to set the clearance to the correct number and then lock down the nut.
I would not attempt it yourself if you are not 100% confident that you are doing it right.
