Thread: 1999 mercury mountaineer 126K miles 5.0 V8
    Senior Member PD code 805D's Avatar
    black hollywood ga
    Default 1999 mercury mountaineer 126K miles 5.0 V8
    :boobies: :boobies: 1999 mercury mountaineer:boobies: :boobies:
    Vehicle Highlights
    Mileage: 126,000 Engine: V8 5.0 Liter Transmission: Automatic Drivetrain: 2WD
    Selected Equipment
    Change Equipment
    Standard
    Air ConditioningCruise ControlPrivacy GlassPower SteeringAM/FM StereoRunning BoardsPower WindowsDual Front Air BagsAlloy WheelsPower Door LocksABS (4-Wheel)Tilt WheelRoof Rack
    Optional
    Rear AirPremium SoundNavigation SystemSingle Compact DiscLeatherDual Power Seats
    var ord = (typeof(globalOrd)=="undefined") ? 1208223655 : globalOrd;document.write('');if ((!document.images && navigator.userAgent.indexOf('Mozilla/2.') >= 0) || navigator.userAgent.indexOf("WebTV")>= 0) { document.write('');}
    Blue Book Private Party Value
    Private Party Value is what a buyer can expect to pay when buying a used car from a private party. The Private Party Value assumes the vehicle is sold "As Is" and carries no warranty (other than the continuing factory warranty). The final sale price may vary depending on the vehicle's actual condition and local market conditions. This value may also be used to derive Fair Market Value for insurance and vehicle donation purposes.
    Vehicle Condition Ratings
    Check Vehicle Title History
    Excellent
    $4,395
    • Looks new, is in excellent mechanical condition and needs no reconditioning.
    • Never had any paint or body work and is free of rust.
    • Clean title history and will pass a smog and safety inspection.
    • Engine compartment is clean, with no fluid leaks and is free of any wear or visible defects.
    • Complete and verifiable service records.
    Less than 5% of all used vehicles fall into this category.
    Good
    $4,020
    • Free of any major defects.
    • Clean title history, the paints, body, and interior have only minor (if any) blemishes, and there are no major mechanical problems.
    • Little or no rust on this vehicle.
    • Tires match and have substantial tread wear left.
    • A "good" vehicle will need some reconditioning to be sold at retail.
    Most consumer owned vehicles fall into this category.
    Fair
    $3,570
    • Some mechanical or cosmetic defects and needs servicing but is still in reasonable running condition.
    • Clean title history, the paint, body and/or interior need work performed by a professional.
    • Tires may need to be replaced.
    • There may be some repairable rust damage
    HERES THE SCOOP ON THIS CAR
    I BOUGHT IT FOR 500$
    PUT 1000 INTO THE MOTOR TO GET IT TO RUN
    1. REPLACED OIL PUMP $27.00
    2.REPLACED REAR MAIN SEAL$12.00
    3.REPLACED TIMING CHAIN SEAL$14.00
    4.REPLACED TIMING CHAIN AND GEARS $27.00
    5.REPLACED CRANKSHAFT $178.00 (CRANKSHAFT WAS FAULTY FROM FACTORY)
    6.REPLACED MAIN BEARING AND SHAFT BEARING (CAME WITH CRANKSHAFT KIT)
    7.RADIATOR FLUSH(BC THE MOTOR WAS REMOVED)
    8.ENGINE FLUSH(TO CLEAN THE MOTOR OF POSSIBLE DEBRIS)
    9.NEW PLUGS $48.00
    10. TIRES ARE GREAT AND BRAKES ARE GREAT.
    * THE ONLY BAD IS THE FRONT HEADLIGHT AND GRILL NEED TO BE REPLACED .AND ABS LIGHT IS ON BUT I THINK ITS BC THE MOTOR WAS PULLED...?
    I AM ASKING $3,500
    678 577 9110
    Attached Thumbnails Attached Thumbnails -cars-004-jpg   -cars-001-jpg   -cars-002-jpg
    need CA$H? I WILL BUY YOUR STUFF OF VALUE.... PM ME WHATCHA GOT!
