Results 1 to 13 of 13
Thread: little fuel problem
    southside ATL
    Default little fuel problem
    alright, so the deal is a fuel problem i believe. Sometimes when driving steadily with my foot on the gas it will lose power like im not stepping on the gas, and u can obviously see the speedometer go down. i take my foot off the gas and press it again and the car jerks like it just got backs its fuel?? Sometimes when it happens i mush the pedal and it will go but then it will still come back and occur. It only happens SOMEtimes. But lately kind of alot. I want to fix this problem before it gets worse. Any suggestions?
    Btw its a jdm b20 swap, with two codes, o2 sensor high voltage bank 1, and another o2 sensor bank 1 code.
    Southside Ridin HATCH
    check the fuel system.. 'Filter,pump, lines, ect'
    Quote Originally Posted by j0natell0
    If you can throw a fuel pressure gauge on there and watch the fuel pressure when you are driving it will tell you if you have a fuel delivery problem before the injectors. It wont identify a bad injector but its a start.
    ^ x2
    yea put a fuel pressure guage on it
    Certified Gearhead schia89's Avatar
    Oct 2008
    If it's not the fuel system check your timing it might of jumped timing.
    southside ATL
    Quote Originally Posted by schia89
    dont think thats it, because wouldnt it be skipping constantly
    soo did u do what was mentioned??
    Oct 2008
    yeah, it would sound just like its not getting enough fuel n either shut off or sputter. just start with the small things first n work your way up
    southside ATL
    just noticed it only happens on cold startup. If i start it up when it wasnt running for a while it will happen. But if i turn it off and start it again and let it warm up it wont happen. ???
    LS Resurrection
    Fulton County, Union City
    maybe your dizzy?
    Do you have a way of logging the parameters in your ecu? Is the ecu chipped?
    southside ATL
    no stock p75 ecu
    my momma's house
    Have your TPS tested.
    Trend settin'
