Thread: F/S F/T !987 Ford Bronco $4500
    DEAD DUCK 1slowep3's Avatar
    Default Sold please delete
    SOLD SOLD1987 bronco 351w edlebrock carb msd coil 20k on motor rebuild and the same on the C6 auto trans.38.5 inch tires 9 inch lift 410 gears it has a detroit ezlocker in the front and a f350 one ton rear end.No cats and true dual exhaust.Thrush mufflers The int is red and a little faded.Everything works like it should and it has good on road manners.Its not too loud.This truck is a beast.It will go where ever you want to go.The truck odometer has over 200k but everything has been replaced or rebuilt.The paint is orig. and has scratches but nothing too deep.There are a few dings but no big dents.It has no a/c and the pass. side vc leaks and the tail shaft on the transfer case leaks a little.I will trade for just about anything as long as its fair.Just make an offer.Keep the neg comments to yourself and ask anything you want.Reps for bumps
    Vin #1FMEU15H4HLA41364
    If you know better do better!
