Results 1 to 10 of 10
Thread: ClutchMasters Clutches/Aluminum Flywheels
    Apr 2009
    Default ClutchMasters Clutches/Aluminum Flywheels
    http://www.corsportusa.com/store/cat...acturers_id=55
    All Categories
    The FX100 System uses the Power Plus I Pressure Plate with a custom heavy-duty Steel Back Organic friction disc. This clutch is engineered for heavy-duty street use. It is specifically designed for extended wear and additional clamping force for the enthusiast who has added an exhaust system, an intake system, up to 50hp NO2 upgrade, or other non-forced induction external bolt-ons. It features only slightly increased pedal pressure, longer life than stock, and normal clutch feel during engagement and disengagement for a very smooth operation.
    The FX200 System uses the Power Plus I Pressure Plate and a Steel Backed Kevlar disc. This clutch is designed for the street enthusiast or weekend racer. The FX200 offers similar torque holding capacity to the FX100, however, its life expectancy is increased 2-3 times with the Kevlar disc. Our Kevlar friction material is non-abrasive and doesn't score the mating surfaces. It features only slightly increased pedal pressure, significantly longer life than stock, and normal clutch feel during engagement and disengagement for the smoothest operation of any stage we offer.
    The FX300 System uses the Power Plus I Pressure Plate with a Steel Back Segmented Kevlar disc. This clutch is designed for the ultimate street enthusiast or weekend racer running a normally aspirated car equipped with cylinder head work and/or hotter cam(s), or with medium-boost turbo or super-charger, or up to 100hp NO2. The FX300 features only slightly increased pedal pressure, long life disc and positive engagement.
    **NOT RECOMMENDED FOR ROAD RACING**
    The FX400 System uses the Power Plus I Pressure Plate with a custom, extremely durable, Sprung Ceramic disc. This is the ultimate extreme duty street and/or road/drag racing system. It is available in a 4 or 6 wing (paddle) configuration, with the 4-wing being the more aggressive setup (please specify which type you prefer). The sprung hub design allows for moderate dampening in high-torque applications, rendering it much more streetable than solid or rigid designs. This disc is designed for long life, outstanding holding capacity, and rapid heat dissipation.
    Warning: Due to the solid (no Marcel) friction rivet design, the FX400 disc engages very quickly and may chatter slightly in first and reverse. To help alleviate this problem, we only use premium ceramic friction material.
    The versatile FX500 System uses either the Power Plus I or Power Plus II Pressure Plate along with a solid center 4 or 6 wing (paddle) Ceramic Button disc. It is designed for maximum holding capacity with no compromises.
    Warning: The FX500 is a Solid Hub (rigid) disc that engages and disengages instantly. This is a Race Only clutch.
    Shipping is always included in the price you see inside the 48 lower United States.
    www.CorSportUSA.com
    Aftermarket Performance Defined.
    Check out VSpeedUSA.com for your domestic vehicles!
    Apr 2009
    IN stock ready to ship!
    www.CorSportUSA.com
    Apr 2009
    www.CorSportUSA.com
    Apr 2009
    Available and ready to ship!
    www.CorSportUSA.com
    Apr 2009
    www.CorSportUSA.com
    Apr 2009
    Ready to ship!
    www.CorSportUSA.com
    Apr 2009
    Always available!
    www.CorSportUSA.com
    Apr 2009
    Ready to ship.
    www.CorSportUSA.com
    Apr 2009
    Clutches from mild to wild.
    www.CorSportUSA.com
    Apr 2009
    Ready to ship!
    www.CorSportUSA.com
