Thread: 91 si with LS trouble starting
    Default 91 si with LS trouble starting
    swapped a OBD1 LS into a 91 EF si. used original SI engine harness and converted OBD-0 dizzy plugs to OBD-1 and using a OBD-0 PR4 ls ecu.
    the car does in fact start. you can hear it run and everything.... but it dies right after. so basically.... start, run.. die, start, run... die, same thing over and over and over, every now and then when it starts it runs for a few seconds longer and you can hear that the motor is running very healthy.
    ive checked tranny, VC, and thermo housing grounds. ive changed the injectors with another set that i know works. i even checked the main relay and thats good..... shit im stumped lol
    if it matters the car has been sitting for well over 6 months..
    help will be greatly appreciated and will be repped
    L-Ville
    is it grounded good? that was my problem
    Quote Originally Posted by Purple Power
    i dont work on ef so i cant say u did something wrong there. so im goign to start simple and ask if there is any CELs. ill let somebody else handle the obd0 wiring crap.
    umm no CELs. turn key, let prime. cel does not come on... try to start and keep trying to start CEL doesnt come on... so im assuming no cels?
    known as Charles
    So you are using an OBD1 dizzy and an OBD0 ecu. That will not work. The way the sensors in the dizzy read are different between OBD0 and OBD1. Try to either get an OBD0 dizzy or OBD1 ecu.
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    Quote Originally Posted by Main Stream
    will do, imma change it today and update
    i knew something sounded fishy about that. just wants my thing.
    ok, i found the problem and now i feel dumb lols. it was the dizzy, crunk right up after i swapped it out with a OBD0 dizzy.
    lesson learned, stupid OBD zero
