Thread: Need Help identifying Turbo
    Ace club Theta Man 96Plumls's Avatar
    Default Need Help identifying Turbo
    I was told that the turbo was a T04e 60 trim
    - but I think it's a T04s
    - the cold side is a .60 AR and the Exhaust Housing shows .70 AR
    - and in between there is a Y4 stamp in the middle
    "It only takes a few weeks to pledge, but it takes a LIFETIME to be a brother."
    Anyone know?
    I keep it real. AFSil80's Avatar
    Savannah
    Is there any sort of metal I.D. plate on the center section?
    -91 240SX -- CA18 Power...SOLD, now terrorizing the streets of Alabama
    No metal id tag
    It looks like a to4e cover and its a journal bearing. It appears to be a t4 turbine housing but it may be the pictures. You can measure the distance between the bolt holes to see if its t4 or t3. If you take off the housings and measure the inducer and exducer of the turbine and compressor wheel it will be easier to find out what it is.
    Ok I thought that it may be a T04e but stock non modified T04e highest trim is a 57, Thanks also +1
    Quote Originally Posted by 96Plumls
    If you take off the wheels and measure them you can tell what trim it is. The markings on the housings are not trim they are a/r. Thats the area of the scroll versus the radius.
    I know that isn't the trim , but I thought i saw somewhere that it doesn't come in a 57 trim
