View Poll Results: how often do you do a boost leak test?
Voters
43. You may not vote on this poll
  • once a month
    5 11.63%
  • once every 2 months
    1 2.33%
  • once every 3 months
    1 2.33%
  • only when my car isnt ruuning right
    27 62.79%
  • whats a boost leak test?
    9 20.93%
Results 1 to 25 of 25
Thread: BOOST LEAK TEST???
    Default BOOST LEAK TEST???
    i was telling a friend today to do a boost leak test and how beneficial it is to making sure your turbo car is running right and it got me thinking. the "SRT4" is really bad about getting leaks and i do a boost leak test every month. do evo, sti, turbo honda, sr20, ect guys also do boost leaks tests this much? i know with my car just cause the gauge tells you its boosting right doesnt mean you dont have leaks and if it does the car isnt running at its full potential. so to get my question answered use the poll cause im interested in what everybody else does.
    4cyl Hemi Turbd4DE's Avatar
    K Town/Barrett Pkwy
    I will test just when ever I think about doing one. Unless my car is acting up.
    ASAP NorthWest Ga Chapter VP
    www.ASAPCarClub.com
    Kennesaw MEET Check it out>>>>> http://www.importatlanta.com/forums/...d.php?t=250694
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    I use good couplers, piping that fits, and a good quality set of T-bolt clamps. I check it if I have a problem. It has never once leaked so far, up to 30psi.
    Who knows?
    140 on one wheel
    columbus, ga
    i use ti check mine almost every weekend...ill be doing that again here soon after my civic is done
    Quote Originally Posted by chad@competitionclutch
    We do them when we think there is a problem.
    I guess if you are confident with the work done on the car and all the connections then you dont have to do it all the time. If you have beads on all your pipes, good tbolt clamps, if all your vacuum lines have clamps on them then you should be good to go for a good period of time. I think its good to visually inspect it at every oil change.
    Quote Originally Posted by Batlground
    yeah i should take up my boost leak issues with dodge fore sure
    the car is on stock intercooler, stock intercooler piping and stock vacuum lines. the intercooler and piping has never been off the car and 90% of the vacuum lines have never been removed and all of them are zip tied nice and tight.
    then again these cars are bad about little leaks but it makes a difference when you lose a .5 PSI and the boost falls off faster toward redline. im pretty sure if it wasnt for boost leak tests i would have never gotten the car into 12's with $200 of HP increasing mods.
    i guess other cars out there arent as bad with leaks so it isnt needed as much.
    140 on one wheel
    columbus, ga
    sr20's get leaks alot to as well as dsm's
    buford ga
    if you own a srt4 u should check it like every other week ROFL!! mine had leaks from hell and back.
    IA MEmber
    was doing one once a week on my MR2... had a leak down tester and a compressor that was always hooked up so i just figured hell why not lol
    We actually just had a SRT-4 come in with boost leak problems. Started at the last hot pipe/hose before the intercooler and then when that one was fixed it blew off the pipe running to the Throttle body and then after that one was fixed it blew off at the turbo outlet. His pipes had all been modified tho. and we ended up replacing or fixing all of them.
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Only checked once since I had my Talon. Never had a leak yet. (knock on wood) I have very high quality couplers and clamps though. How ever usually when I have the hood up I do inspect all the connections.
    The REAL Scrapy :)
    Oct 2008
    I check for boost leaks everytime I remove anything on the intake tract and have to put it back on
    1990 Eclipse GSX - 13.0@ 108 on old setup
    1990 Eclipse GSX - "The Whore" Shell being built
    2001 Dodge Dakota - The pizza delivery-mobile
    dc5
    ATL, GA
    do it right the 1st time and don't gotta worry about it.. Half-ass it and you will always have to
    Canton
    I have never had a problem out of my RX-7, Guess thats what happens when its done right.
    Try not. Do or Do not.
    D0 W3RK RedEj8's Avatar
    Macon
    MkIII Supra's tend to get boost leaks all the time.. 20 year old rubber couplers + worm screw clamps = boost leaks.
    People make the leak testers using plumbing materials.
    Quote Originally Posted by Axix23
    thats a ignorant statement.
    LOL at all the SRT-4's. I had a friend that I rode with and when he hit boost it would make this loud whisling noise. I told him it was a boost leak but he wouldn't listen. Finally when he dynoed it and it didn't make the power he believed me. I made him buy my dinner for that.
    Better watch your back...before you get the NINJA SLAP
    MCD
    i know what a boost leak sounds like and how it feels so i dont have to check it at all unless i feel a problem or my boost controller shows other wise
    SUPERMAN
    Oct 2008
    Summerville, GA
    Only when I think something is wrong then I will test it.
    (SRT EQUIPPED) It's Just A Neon...
    1/4mile= 11.21 @ 127mph 2.0 60ft
    The Boost Is Strong With This One.
    If You Can't Say Anything Nice,
    "Then Go F**k Yourself"!!!
    AccuracyPerformanceAutomotive
    Default I would test anytime you mess with the intercooler piping.
    500whp of spinnin fury!!!
    I did one tonight actually. I knew i had a leak, but couldn't pin-point it. So i finally did a test. it was at the 2nd coupling on the hot pipe, the tbolt clamp had loosened itself.
    All Brandname Turbonetics Couplings and Tbolt Clamps, and i still have leaks from time to time. Its not always about "quality products", Things happen, cars wear down, air finds ways out after time.
    Go kick it sideways boostleak's Avatar
    Southern Georgia
    did some one say boostleak?!
    On a serious note, no i haven't at least not yet because i don't need to.
    A wise man makes his own decisions, an ignorant man follows public opinion.
    everytime i mash that right side pedal. test results...boost. must not be leaking.
    seriously though, only when there is reason to believe their is a leak. never had to do one on my own car.
    aka....RAFA RJ's325ITS's Avatar
    Stockbridge, Ga.
    There are a lot of things that had to be in consideration when to do a boost leak.
    1. If you running a draw-thru setup then you will feel it (car will misfire at times when the leak is big), and you will see it (A/F ratios will be way off target.
    2. If you are in a blow-thru setup then you will not fell it since the leaking air hasn't been metered yet, but you will be able to see it by not achieving the desired boost level. But sometimes the leak is a cracked VAC line so you will not even see it.
    3. There are numerous problems that have the same symptoms as a boost leak.
    Most of the time after a asking the costumer a couple of questions I know if a boost leak test is a must, or if a visual inspection leads first.
    Rafa
    TRM Stage 2 │TRM Coilovers │ TRM Pistons │ TRM Blowthrough Tuning │ TRM MAF & Injectors │ Watch My Crazy Videos
    ???????? JR VQ 30 de's Avatar
    man i need to do one asap
