Results 1 to 26 of 26
Thread: Nice car with problems
    GWINNETT IS GREAT!
    Default Nice car with problems
    so my friend bought an 94 integra gsr for $1800. This morning, we drove all the way to macon (from winder) to pick this car up. The car had not been driven for a year so it sat there. However, b4 it was parked by the owners, the car's transmission was replaced and besides that it has some mods on it...
    the problem is the car cannot rev over 4k, so he cannot drive faster than 60mph...CEL also..
    now alot people have told us numerous things. the owners said it is the crank pos. sensor. since then we have heard stuff like o2 sens, map sens, TP sens..
    the car's batt has been relocated to the trunk and its been hissing sulfuric acid..LOL..and its a very old battery so we have to push the car to get it started...
    anyway...iif anyone on here has had similar problems like the car not being able to rev past 4k, please lemme know...
    AND WHERE IS PAUL VUONG?
    friend needs him!!
    Senior Member StreetHazard's Avatar
    Sep 2008
    geezus that thing sounds like a POS, sounds like your friend paid too much for it. I honestly wouldnt know where to begin, it sounds like it could be any number of things...I would certainly start by doing a compression test (which he should have done before he even bought it) that will give you a good idea how good of shape the internals are....if the compression test is very weak. Then I say fuck all the other issues you have because he needs a new motor anyway, then you can go from there. you may luck out and have it be the sensors (a good haynes manual or GOOGLE BITCH will tell you step by step how to test your sensors)
    and and ohmmeter will help you and you will need the manual OR THE MOTHERFUCKING INTERNET to tell you the proper ohm range for OEM specs. I flat out refuse to find it for you
    good luck
    GWINNETT IS GREAT!
    could not find anything on google, but comp test sounds good..
    thanks for your help..
    anyone else?
    similar problems?
    Sep 2008
    whats the block code? B18C1?
    GWINNETT IS GREAT!
    yea
    Get the codes checked and come back to me.
    lol im going to start simple whats the CEL.
    GWINNETT IS GREAT!
    bout to go run codes on it right now
    thanks stay posted guys
    GWINNETT IS GREAT!
    49?
    four long, 9 short?
    Senior Member Maki's Avatar
    Alpharetta
    you sure its 49?
    PEENGONE Hektik's Avatar
    48 LAF - lean air fuel sensor i couldnt find anything on ht for code 49
    Alpharetta
    Code 4 Crank position sensor
    Code 9 No.1 cylinder position sensor
    no code 49.....???? recheck?
    Code 48 Heated oxygen sensor
    GWINNETT IS GREAT!
    could be maki said...
    how long in duration do the long ones have to be?
    GWINNETT IS GREAT!
    Columbus
    ok, well...you said the car cant rev past 4k???? my teg couldn't do that once, right when i bought it. turns out i had the wrong ecu......could be why you are throwing codes as well. just a thought
    what ecu do you have in it?
    edit- has the car been doing it since the begining?
    GWINNETT IS GREAT!
    since we got it...they said it started doing that some time after they changed the transmission...which is a b16 si tranny....
    dont think it could be the wrong ecu since the engine is stock....
    Alpharetta
    there is a noticable difference in the short/long flashes. there will be no mistaking the difference
    GWINNETT IS GREAT!
    then it must be 4 and 9...
    where is the crank pos sens located?
    is there a noticeable pause between the long and short flashes, or is the pause between the long and short flashes the same as the pause between all the short flashes. i would be willing to bet it's code 4 and 9 as was stated earlier. both are for crank positioning and cylinder positioning. if that's the case you're in limp mode and the car is trying to save itself from you reving it when it doesn't know how/when/why to fire.
    Alpharetta
    I agree. Sounds more plausable
    Alpharetta
    Quote Originally Posted by 98blackcivic
    Usually in the dizzy i believe, correct me if im wrong. havent worked on a honda in a while
    Quote Originally Posted by Maki
    crank cam and tdc all same sensor in the dizzy
    GWINNETT IS GREAT!
    friend is going to buy the part today and get it replaced at this place...
    im trying to confirm, if the older motors have the sens. in the dizzy, the newer, obd2 have them around the crank shaft? near the water pump...?
    GWINNETT IS GREAT!
    so the car is in limp mode and wont rev past 4k....i guess its a common problem..
    limp mode yes that sensor blowing not so much.
