Results 1 to 19 of 19
Thread: laptop wfi troubles..
    ALL CAPS JITB's Avatar
    Default laptop wfi troubles..
    So we upgraded to wireless at home yesterday. And everything works fine.. except the laptop.
    It says its connected to the router etc.. says it has a excellent connection...But, i cant bring up any sites. It has been connected thru a wire before and ran fine. but no sites are coming up? its a dell d630
    Nordic Sled cjhutch's Avatar
    TCP/IP settings. Right click on the network and then go to properties. You will see a tab for TCP/IP settings. Make sure under there the options to obtain an IP address automatically and Obtain DNS server automatically are checked. If they are not you will probably see an IP and DNS that's all zeros.
    K-Town!
    Is the router broadcasting in the same wireless frequency as the laptop? b/g/n?
    Quote Originally Posted by The Ninja
    not sure the one in the laptop already came already in it, how do i find out which one?
    I don't think that's the problem. All modern laptops with wireless cards have b/g compatibility and routers are also backwards compatible if it's an n capable router. Also he says he has connection to the router, but just can't get on the internet. When I was a network admin the kind of problem he described almost always was the TCP/IP settings.
    Quote Originally Posted by cjhutch
    i cant get to the ip settings, the laptop is from school.. will i need admin prviledges to do so?
    Hmmm, I don't think so. I don't have a PC right now to test it. If you can't get to those settings it will tell you that you don't have sufficient privileges. Just to make sure you are going to the right place.
    Go to your control panel and then click on network connections. Find the wireless connection in the list. Right click on that connection and then click properties. From there another box will pop up and look for the option that says TCP/IP Connection. Click on that and then click on the button labeled properties. You will see the next window and from there the Ip and DNS settings boxes will be towards the bottom. Click on the box that says obtain automatically for both.
    it says they both are automatic..
    01civic
    Henry County
    go to start - run - cmd - then type in ipconfig /all and paste what it says for us
    i dotn have the cmd option, when i click RUN, it goes straight to search function
    needs moar linux
    atlanta,ga
    Try right clicking on the network connections icon and see if you can do a repair on that connection. Sounds like you may need admin privileges if you can't change any ip settings.
    I have a similar problem, it was working and now she don't work. It say's I'm connected but can't access the internet. When I tried fixing it it tell me I need the network admin. to fix it? I am the admin. what should I do?
    zoom-zoom-zoom
    Quote Originally Posted by 92mr2T
    wont let e repair..b/c it says nothing is wrong..
    Apr 2009
    go to your hardware config and uninstall the wireless adapters drivers and reinstall them.
    Same problem here with my brother's laptop.
    Quote Originally Posted by BlizzCivic
    Under "Windows IP Configuration" the part that says "IP Routing Enabled..." says No...should that say yes?
    Disregard that....I ran the ipconfig on my desktop for comparison and it says no as well. The default gateways and stuff do show up blanks though and i get considerably less information on the laptop than i do the desktop
    NC
    have you found the IP settings yet?
    PM to JITB. It's what did it for me
