Results 1 to 3 of 3
Thread: HYTECH RAGE STYLE BIG TUBE Tri-Y Header GSR B16 VTEC
    Hand Built Self Made batlbrandon's Avatar
    around
    Default HYTECH RAGE STYLE BIG TUBE Tri-Y Header GSR B16 VTEC
    Email for special IA pricing. [email protected]
    FITS THE FOLLOWING:
    ALL B SERIES ENGINES! WILL FIT CRX AND DA WITH AFTERMARKET TRACTION BARS. ITR MUST REMOVE TRANS BRACE FOR PROPER FITMENT.
    BASIC INFORMATION ON THIS HEADER
    15whp+ OVER A STOCK B18 HEADER ON A 2.0 LITER
    10whp+ OVER DC JDM HEADER
    This is a version 2 Header with the redesigned thicker and stronger flange.
    Piping size on this header is as follows; Primary tube off the flange out of the head is 44.5 mm. The piping then steps up to 48 mm. The 4-2 Tri-Y is 50.8 mm and then the 2-1 Tri-Y is 54 mm. Then the collector is 65mm (which is 2.5") The piping at the flange is welded on the inside and the outside.
    ---Will fit with AC and PS
    ---these are brand new in the box
    ---Made of 304 Stainless steel
    ---1 year limited warranty
    ---Long tube tri-y header
    ---2.5 collector
    ---Machined CNC manifold flange
    ---18G on the 304 S/S. Measured at .049" to .050"=
    ---Flange is .38" which is just about 3/8" thick ---18G on the 304 S/S. Measured at .049" to .050"
    ALL HEADERS COME WITH EXHAUST MANIFOLD GASKET, HARDWARE, AND DONUT GASKET!
    DYNO PROVEN, 15+ WHP GAIN BY BOLTING IT ON, 20+ WHP WITH TUNING
    top
    up
