Results 1 to 16 of 16
Thread: HELP ME GOTTA MAKE THEM FIT
    ~THE UNDER DAWG~ ghostfacekil's Avatar
    Exclamation HELP ME GOTTA MAKE THEM FIT
    i need help what do i have to do in order to get these to fit on my ej ? i know fender rolling is a deffinate .....
    16x8
    4x100/114.3
    +0 offset
    West Staines
    is the car dropped?
    although its not necessary in some cases... do you have a camber kit?
    you NEED camber.
    you need to roll a bit.
    and no no camber kit yet
    West Staines
    well if at all possible get one just to be sure. better be safe than sorry. I've seen the 15x8 +0's on Civics but im a tad concerned with the possible difficulty of fitting the 16's. I KNOW they can fit so don't sell the wheels just cuz you may encounter some difficulties. its a Honda we always work it out.
    Middle, Ga
    Yeah, I've seen the 15x8 on Honda's but 16x8... Gonna be more of a challenge.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    thanks again Do yeah your right we honda owners will make it work but hopefully they will be on soon
    15x8 vs. 16x8? What's the wheel size have anything to do with it? It's the tire size that counts and as long as it has the proper outside diameter it will fit the exact same. Go up a wheel size then need got go down a size in profile/series on the tire.
    West Staines
    doesn't have much to do with it but maybe rubbing may pose as an issue depending on how low he is?
    Southside of The Jungle
    yea 16x8s are a tight squeeze but a little bit of rolling and youll be ok.Depending on the profile tire you are trying if its not 205/40/16 then you might have a problem.
    Member
    Carrollton
    The problem with 16's is the lack of tire size. Try to find a 195/40 or 195/45. If all else fails go 205/40. Nothing bigger.
    Camber and a little roll, and your set!
    98 Subaru Legacy GT
    89 325i. 400hp hoon-mobile.
    If the tire is the same outside diameter then he can run 15, 16, 17's, or 18's and not rub any more or any less. Go up a wheel size then you have to go down a size in profile. It's common sense and simple math.
    Without having an adjustable suspension ie: coil-overs and camber plates it will be difficult to fine tune the stance, especially with a deep offset wheel that's going to stick out. If you want the tucked, poked, stretched look and everything then you have to be willing to pay for quality suspension components to prevent body roll ie: sways and high quality coils & dampeners other wise you end up with dented fenders and shredded tires.
    There is nothing more irritating then having a cars tires scrub because of improper fitment and inferior components!
    Krispy Kreme
    from what i know, 205/40/16, with neo-gens. camber, with a pull in the fender or roll! then get aligned!
    NIKOND80
    PG+K
    93coupciv metro larev's Avatar
    canton ga
    im about to put a pair of 205 40 16s on my 93 civic the with is 7 and i wasnt sure if i was going to fit really well cause i dont know where to get my finders rolled any help there? i could really use it
    Sep 2008
    lithonia
    adrenaline tuning can roll you up. give them a call.
    404.284.7000
    Slimm
    GOONie blue_lude_91's Avatar
    Ft. Worth, TX
    16 0 offset look weird on a ej, i remember seeing a guy on hondatech with that. theyll fit forsure, youll need alot of pull though but you can get em on there. the 16's look too big IMO
    Here are a few Pictures of the Fender Rolling We did yesterday. Customer was running 285s for the track. And this was a pretty aggressive roll.
    Here is some from Today.
    Zen Motors LLC
    Local Phone:770.904.2868
    E-Mail: [email protected]
    Website:www.ZenMotorsLLC.com
