Thread: DSM Guys...Limp Mode Issue..
    Default DSM Guys...Limp Mode Issue..
    I have a 92 Laser turbo, it's A/T, FWD, it is in limp mode, aka stuck in 3rd gear, has P,N,and R, but no forward gears but 3rd (no matter what "gear" I put it in, it's 3rd.)
    I have reset the ECU, I have started tracing some wires, now have the TCU out and am inspecting it. See pics, does it look bad? If so, repairable? I know there are manual shift boxes that bypass the TCU's limp mode function.
    Also the speedometer quit working, but it was in limp mode before that. Is that going to send an error? BTW there are no codes, and no CEL.
    Stereo Junkie TSiFTW's Avatar
    Apr 2009
    Looks to be the TCU. Around this age they and the ECU start to go bad a lot. Notice the burn marks, those are usually bad. Just to make sure have you hooked up an auto timer or anything that you had to mess with wiring? That will often cause a limp mode also.
    I checked the ECU it's clean inside, and has a marking, looks to be a used replacement.
    I was worried about those burn marks. Nothing has been added. The owner before the PO did have some ghetto rigged stereo wires and such, but I think I got most of those removed, and checked all fuses.
    it is toasted. spring for a remaned. dont get a used 1 with just as much age on it.
    Apr 2009
    Quote Originally Posted by TSiFTW
    I reread and see that you probably dont have an auto timer. I would say probably your TCU then. They are repairable if you are knowledgable with working with electronics. Most people just get a new one.
    DUH-KYOO-LUHHH
    ^^ im with that guy
    Yeah I will go find one, or I have read you can get a manual shift box and it bypasses the TCU's need for limp mode?
    Apr 2009
    Like he said get a reman one. The ecu and TCU are at the age to start failing, so most likely a used one won't last long.
    I think they are like $250 for that if a manual shift box is less and will fix the issue I'd personally rather do that. Or figure out how to make one lol.
