Results 1 to 10 of 10
Thread: DIFFERENCE BETWEEN 93 and 94 integra clutch kit
    ballin on a budget hondalover00's Avatar
    ga
    Default DIFFERENCE BETWEEN 93 and 94 integra clutch kit
    i have a clutch kit for a 93 integra and i want a gsr hydro tranny....what is the difference between the two kits..i think the spline count is the same..lmk..any info would help me out
    As long as the splines are the same, run it.
    ga
    i think that the throw out bearing might be different...anyone help?
    hydro & cable clutch kit are different!!! splines are the same but it will not fit in there firmly. And is your 93 teg hydro converted already?? cause you cant just decide to run a hydro tranny whenever you want to 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    southside ATL
    whats the difference between big spline and little spline.. i just traded my itr tranny so im about to get a 95 ls hydro tranny, just wondering if it will fit mine..
    sorry to threadjack btw bro
    yeah it fits! but what i'm talking about is the clutch difference of cable & hydro only .. Bsereis transmission are interchangable .. from
    /Oo ___A___ oO\
    |=_/_______\_=|
    ga
    Quote Originally Posted by VickNotic
    the disc fits on the spline fine on a 94 integra ls hydro and same fitment on my 93 integra gsr cable tranny....how would the fitment be different of what your talking about
    well then you must have some sort of universal clutch disc or something then..
    cable and hydro clutch kit are there for a purpose for users application. if you have a cable tranny you'll need a clutch kit that is for ur cable tranny! you can find out the hard way and later on the splines will be rounded out within months 8D
    /Oo ___A___ oO\
    |=_/_______\_=|
    known as Charles
    The spline count is the same for the 92-93 cable b-series and the hydro b-series. The internal parts are the same just in different cases. The throwout bearing will be the only thing that is different. This is the reason clutch companies have different part numbers for the cable and hydro kits (look up ACT and you will see that everything in each kit is exactly the same exept the throw out bearing).
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    ga
    Quote Originally Posted by Main Stream
    thanx for this
