Results 1 to 17 of 17
Thread: Someone please refresh my memory real quick
    Default Someone please refresh my memory real quick
    Single cylinder 2 stroke engine, 30ish PSI compression. Dump a little oil in the cylinder and retest. Jumps to 90. Bad rings?
    BMW 750iL
    2wheels move ur soul
    yep.
    Yea or worn bore alot of times on 2-stroke. Make sure you measure bore taper and bore roundness.
    Thanks guys. I will as soon as I can get the head off of it. Stuck on there.
    BMW 750iL
    You ever come across a good deal on a stand up ski?
    Yeah, got 2 right now. Take $200 for either one. One is a JS300 and the other is a JS550. The 300 (one in question now, needs rings, have ordered, be here next week) and the 550 needs pistion/rings.
    I got the head off, cylinder has some scratches but should be ok with hone/re-ring.
    BMW 750iL
    PM me some pics of the js550! Does it run at all? why piston also?
    Pics can be found here. Doesn't run at all right now, no clue why it needs a piston. I haven't had time to look at it.
    http://www.importatlanta.com/forums/...9#post38067509
    BMW 750iL
    where are you located? hows the hull on it?
    Conyers, but since your in Dahlonega you can come to the office in Norcross. The hull looks good, water tight.
    BMW 750iL
    If you think about it, snap a few more pics when you've got a chance, i would def be interested in picking it up from you.
    Alright
    BMW 750iL
    Here is the 300 also. Hull has been repaired before, just needs finishing but is water tight.
    BMW 750iL
    LOL well atleast i know it will fit in the bed of my tacoma now
    The other one will also, same size hull.
    BMW 750iL
    Quote Originally Posted by SuperChicken
    yep.
    x2
    Sold within an hour on CL today.
    BMW 750iL
