Results 1 to 15 of 15
Thread: What caused this? Piston failure
    Default What caused this? Piston failure
    This is a Jet Ski engine (900cc 3 cylinder 2 stroke). What caused this piston failure? The head on this cylinder also looks almost like the top of the piston.
    BMW 750iL
    Lean. Probably a jetting or sp plug issue.
    My thoughts exactly. Thanks.
    BMW 750iL
    Oct 2003
    Is it boosted? Look like you leaned out.
    No its not. I'm thinking a carb gasket started leaking or something. Has less than 100 hours on the engine. All stock.
    BMW 750iL
    lean all day
    Canton
    Lean, or your Pre mix was WAY off.
    Try not. Do or Do not.
    110% lean
    Quote Originally Posted by eraser4g63
    Its injected.
    BMW 750iL
    villa rica, ga
    then the injector wasnt working properly or someone 'adjusted' your carbs and then one of your buddues decided to 'floor it' for say 20-30 min and that's what happens sorry, happened to me back in the day too
    MabletonSpeedShop member
    MCE Mafia supporting member
    honored to be MCE Dec'08 rotm
    So... how do you go about adjusting the carbs? It has 3 of them.
    BMW 750iL
    sync and re jet
    slick fricks sikfricks's Avatar
    ROME,GA
    2 stroke jet skis are really sensitive i would never trust the injection just premix the gas this has happened to me numerous of times i learned the hard way p.s buy my jet ski
    <img src=http://www.importatlanta.com/forums/image.php?type=sigpic&userid=19661&dateline=1274467236 border=0 alt= />
    You can't remove the injection system on this ski but I am going to premix the gas 50:1 anyways along with the oil system. Thats what Kawasaki recommended.
    BMW 750iL
    Quote Originally Posted by sikfricks
    Check your PMs.
    BMW 750iL
