Thread: vtec controller??!!!!
    Default vtec controller??!!!!
    my ecu is not letting vtec engage can i use a vtec controleer to make vtec work if i wire it to the dist... and the vtec solinoid instead of the ecu is this possible need help asap
    A.K.A Felipe Gomez Negrodamus's Avatar
    Daaaaaaknessss
    How bout just a new ecu. makes no sense in paying for a vtec controller and ghetto wiring it the dist or the vtec solinoid when u can easily replace the ecu. btw are u sure its the ecu? check the oil pressure? could the vtec solinoid be bad? can it be cloged oil filter in the soilnoid?
    i really dont know what the problem is if you wire vtec to a push button hit it at 5 grand and what do you know you have vtec i put my ecu in a buddys car and everything worked fine this is the reason i was gonna run the controller i need help on this fast right now the car is at a shop and they cant figure it out they want me to buy all these parts that i think i dont need they redone my harness i had but want me to buy another one they said it could also be my chassis harness all i want to know is can i make vtec work with a controller im tryin to get the car done for import showdown sunday
    known as Charles
    if VTEC wont work with a proper ECU, then a VAFC wnt help, its a band aid. what CEL is it throwing. only certain things can cause a car not to hit VTEC
    Oil Pressure
    Vtec SOlenoid
    Knock Sensor
    VSS aka is your speedo working?
    Main Stream Performance
    www.mainstreamperformance.com
    MSSracing.com
    #1 casting agency
    Atlanta Ga
    Quote Originally Posted by Main Stream
    Oil Pressure
    Vtec SOlenoid
    Knock Sensor
    no cel vtec works on push button and also speedo works
    Quote Originally Posted by Georgia_Casting
    if you have no CEL, then its a solenoid or oil pressuer problem.
    check to see if you are getting power to your solenoid. then clean the screen on it, then make sure all wires and hooked up and grounded correctly, and make sure you have oil.
    there is something seriously wrong with that car
    Jan 2005
    Columbus, Ga
    Quote Originally Posted by nitrousfedsi
    they are giving you good advice....but honestly, if you want it fixed, try and make an appointment with Main Stream performance
    i know you love my swagger
    OG Black Delegation member
    RIP My Homie Elliot Sloan
    #1 casting agency
    Atlanta Ga
    who do i need to ask for at mainstream
    Jan 2005
    Columbus, Ga
    Charles or Mike...they both posted in this thread for you...you can PM Vteckidd or Main Stream...they will defintly take care of you.
