4AGE Turbo manifold + DSM T25 turbo. The exhaust manifold is cast and a T25 flange was welded on (at a professional machining shop using nickle rods). Two braces were welded from the manifold to the flange to provide structural support. The manifold was ceramic coated with cast iron paint. The DSM T25 came off a 2nd gen Eclipse, and has new oil seals installed less than 500 miles ago. The turbo spins freely has minimal shaft play, and zero in and out play. It will work with the stock oil filter, starter, and AC compressor.
It has a stainless steel o2 housing and I will also include the 2.5" downpipe + flex pipe as shown in picture. The oil feed port has a banjo bolt with -4AN male fitting, which means it will work with any universal T3/T4 oil lines.
This turbo set up came off my 4AGE MR2, but will fit any 4AGE motors including AE86, AE92 Corollas (You just have to direct the downpipe in another direction). The stock wastegate is set at 9 psi and it pulled strong. This turbo starts spool at 2000 rpm and hit full boost by 3000 rpm. It was working fine before removal from the car.
My price is $250 cash. Call or text 678-559-9707, Tim
