Thread: 1999 Honda Civic no start .. need local help
    Certified Gearhead incawarrior's Avatar
    Snellville, GA
    Exclamation 1999 Honda Civic no start .. need local help
    I'm in Snellville, GA and here is what I've done so far.
    Replaced coil
    replaced ignition module
    replaced cap/rotor
    replaced spark plugs.
    And the Honda ignition switch recall has been done.
    I still get a no spark at the plugs and wondering if I have a deeper issue.
    Local parts place advised to replaced distributor, Then I read on H-T where ECU and or Fuse go bad.
    Is there anyone local with a good ECU to test?
    Even my Ford diesel wasn't this hard to fix.
    Thanks!
    2000 Ford F-350
    1998 Honda Civic
    1982 Porsche 911SC
    your moms house
    check uot parts for sale u mite find a cheap ecu there
    (((((No more 4 door))))))
    Snellville, GA
    Quote Originally Posted by civic gsr
    yep.. saw a couple there.. I need to get the numbers off of mine though... brb
    2000 Ford F-350
    1998 Honda Civic
    1982 Porsche 911SC
    your moms house
    what kind of motor u have u mite be able to fit another one in it ifyou do research
    aye bro .:Stirfry:.'s Avatar
    did you check the main relay
    ATL DAsquad Member #9
    Snellville, GA
    sucess. bought a dizzy, installed it and BAM fired right up. sheesw...
    2000 Ford F-350
    1998 Honda Civic
    1982 Porsche 911SC
    Snellville, GA
    thanks for all your help ia
    2000 Ford F-350
    1998 Honda Civic
    1982 Porsche 911SC
