i have a 2005 Kawasaki Mule 4x4 3010 with low hrs , i only used around my house in great shape needs nothing ,ready to work priced 1000.00 below blue book
let me know what u have 2 trade , i am looking for seadoos ,cars , boats or just whatever
please do not wast my time if u are not serious BRING CASH OFFERS-----------------------------------------------
email or text or call
[email protected]
404-543-7468
cash price 5000.00
Engine Four-stroke, liquid-cooled, overhead valve V-twin
Displacement 617cc
Bore x stroke 76 x 68mm
Compression ratio 10.3:1
Carburetor Mikuni BW26-18
Air filter Snorkel-type with cyclone-type two-stage dry replaceable element
Oil filter Automotive-type spin-on canister
Ignition Digital electronic
Electrical 12V DC, 18 amp-hour battery, alternator
Transmission Continuously variable transmission (CVT) with high and low range, forward, neutral and reverse
Final drive Shaft, selectable four-wheel drive with dual-model differential
Exhaust Muffler with USFS-approved spark arrestor
Tires 23x11-10 tubeless
Front suspension / wheel travel Independent, MacPherson strut / 3.9 in.
Rear suspension / wheel travel Semi-independent, De Dion axle with leaf springs and shocks / 2.8 in.
Steering Rack and pinion
Brakes Four-wheel hydraulic drums, sealed
Fuel capacity 5.3 gal.
Dry weight 1,314 lbs.
Overall length 112.6 in.
Overall height 76.2 in.
Overall width 57.5 in.
Wheelbase 73.6 in.
Ground clearance 7.2 in.
Roll over protective structure (ROPS) This structure meets ROPS requirements for wheeled tractors under SAE J1194, 7.1.1, 7.1.2, and 7.5. This structure also meets FMVSS 216 Roof Crush resistance requirement
Cargo bed dimensions (LxWxH) 46.3 x 51.6 x 11.3 /15.6 cu. Ft.
Load capacity 1,330 lbs.
Cargo bed capacity 803 lbs.
Towing capacity 1,200 lbs.
Turning radius 11.2 ft.
Top speed 25 mpg, governed
Instruments Parking brake warning light, coolant temperature warning light, horn, 12V DC outlet, (2) 5/21-watt taillight, brakelight, (2) 35-watt sealed-beam headlight
THANKS 4 LOOKING
