First up we have some 11:1 Compression pistons for a F20/22 C, S2000 They are .020 over. BNIB CP w/ Total Seal rings, clips, pins....
$500 ObO
1.6L Miata Motor with the common "bent snout" motor does run, but is probably missing little knick knacks from when it was removed. Was also slightly down on power, head is good. $100 OBO
D-series Lightweight Flywheel USED, probably could use a resurface: $50
Also with it is a less than 100 Mile OEM exedy replacement clutch : $50
Combo deal for them will be $80
B17A1 from a 93 GSR that I recently removed. Customer said it ran, but it came with a dead battery so I cannot assure it.. It is complete Minus Distributor, I have the Valve cover and other things in a seperate box. Obviously has many leaks, will need some freshening up. We can pull the pan and check the bearings if need be... $650 OBO
More to come later, If there is anything else you need, we probably have some laying around...
